Results 1 to 15 of 15
    Oct 2013
    194
    Gluing the tires
    Hi,
    Dumb question but bare with me for a second please.
    My tires keep flying off cause of the 2S power (I want even better mention what happens with the 3S lol)...
    I want to glue them and the glue I have in my house is -
    http://www3.towerhobbies.com/cgi-bin...&I=LXK286&P=ML
    Is it good for the task or should I use a special tire glue?
    Thanks,
    Barak
    Virginia
    320
    That should work, but why weren't your tires glued in the first place?
    2wd Slash VXL
    3906 MMM
    Oct 2013
    194
    when you buy them from Hong Kong they always send them free so you can do what ever you like...
    Any pros and cons for using that glue and not a tire glue?
    Virginia
    320
    I saw that since you have the CA+, that is a thicker glue, and I believe for gluing tires you want a thin glue so it gets to all parts of the tire and makes solid contact. So, In short it would work to hold the tire on the wheel, but it may not look pretty or be as good as thin glue.
    2wd Slash VXL
    3906 MMM
    Oct 2013
    194
    ok great! thanks bro
    12,314
    I use cheap $1 for 4 tube super glue... my tires hold even on my 80mph 8th scale.
    Most of the good adhesion comes from prep work!!
    Oct 2013
    194
    Your going to laugh at me - I want to say LIKE but my English ain't that great to understand your last sentence there... lol
    Virginia
    320
    He is saying that what makes the bond strong is what you do to prepare the tire and wheel for gluing. Clean the gluing surfaces, and let dry.
    2wd Slash VXL
    3906 MMM
    Oct 2010
    NJ
    868
    I always scuff up/sand the tire and wheel, then clean with nitro cleaner or soap and water, let dry, then glue. You really need to get rid of that super smooth surface.
    12,314
    Yup...
    remove all chrome out of the bead area on chrome rims
    clean with alcohol
    lightly scuff up surfaces
    clean again with alcohol
    Don't touch the glue areas... even your skin oil is enough to weaken the bond.
    Oct 2013
    194
    Great! thanks!
    Any way to take it after it is glued well?
    12,314
    Did you mean "tape" instead of "take"?
    If so, no... not without taking at least one bead off the rim.
    Oct 2013
    194
    hehe sorry, meant take it off - Can I remove the tire off the rim after I glued it (without destroying one of both)?
    12,314
    Boiling, baking, acetone... all these methods work.
    Oct 2013
    194
    Thank you very much!
