Results 1 to 7 of 7
    Dec 2013
    Acworth, GA
    36
    Those with aluminum motor mounts
    All of you that have some form of an aluminum motor mount I have a question. I received my King Headz aluminum motor mount today and installed it. I noticed that the driveline seems to be louder now, yes the mesh is right and the clutch is perfect. I am assuming this is due to the aluminum vs plastic that it is louder? Anybody else notice this?
    Mar 2009
    Williamsburg, OH
    2,532
    I installed my KHZ motor mount and Revo slipper at the same time and noticed a growling noise. I pulled it all apart and couldn't find anything, or so I thought. The growling was caused by the pinion grub screw rubbing on the spur gear. It shaved some of the teeth down. Maybe check to see if you have a similar situation. Mine is as loud as stock since I have replaced the spur and adjusted the pinion gear.
    Was an xl-5, now its vxl-ent!
    Dec 2013
    Acworth, GA
    36
    Quote Originally Posted by dcsally97 View Post
    Interesting, I am not sure how the pinion gear grub screw could have backed out. I don't think that is it, but I will check it.
    Feb 2002
    9,366
    I think you are probably right.
    I am sure the aluminum is amplifying any sound that was already there
    Wales in the UK
    6,462
    I will say mine got louder after I installed the motor mount and plate as jumbo said it's because the stock plastic deadeneds the noise and the aluminium enhances it......peace....ps but less side flex and it will dissipate heat more than stock
    Dec 2013
    Acworth, GA
    36
    I love it so far. I haven't run it again since tightening my slipper up a little, I noticed it was slipping more than usual. I also noticed in the current temps we have been having here before I would get up to 120 or so and it did not go over 100 or so.
    Wales in the UK
    6,462
    Sounds like it's doing it's job already man.......peace
