Results 1 to 12 of 12
    13,238
    How hard is it to switch telemetry to a different motor system?
    I am wanting to put the MMP 2400 motor system in my lcg Ultimate edition. Has anyone else successfully done it?
    Princeville, Québec
    973
    Hi ElSob, i did it a while ago, it is the same as with stock esc/motor. But you must have TRAXXAS Tx/Rx system.
    Summit RX8/1550kv-Slash4x4 MM2/2400kv Twin-V Merv.
    13,238
    So you restrap the sensor to the motor? How is connected to the esc? I see there is a wire that is attached to the Traxxas connector. Do you have to re-solder that to the new esc? Is there a physical sensor to the esc?
    Princeville, Québec
    973
    All sensors connect in the rx. The temp sensor have a plug that connect to the rx, and voltage sensor is connected to the red female plug attached to the temp sensor plug tha connet to the rx. The rpm sensor also connec directly into the rx. There are no sensor connected to the esc, only the voltage sensor have a plug to connect to the traxxas battery connector. You don't have to do any soldering... it is all plug 'n play!
    13,238
    Quote Originally Posted by boilo56 View Post
    So its just a plug? Ok I may have to just go ahead and do it. So basically I just have to put the plug in the new connector and wrap the sensor around the motor and call it a day?
    Princeville, Québec
    973
    I would say so!
    13,238
    I would say so!
    Thank you! I believe this transformation is going to happen sooner than later! Thank you all for for your help! That's why this is a family to me.
    Princeville, Québec
    973
    Well, El Sob, you have helped many people on this forum, so, for sure, it was a pleasure to help!
    RC Turnbuckle Jr. mwe-maxxowner's Avatar
    Feb 2004
    pageland, sc(south of monroe)
    5,697
    I have voltage/temp sensor on my truck. I soldered the red voltage sensor wire onto a modified balance plug. So i plug the sensor to my balance taps on my lipos. I wrapped the wire loop for the temp sensor around the motor and cinched it tight with a piece of tubing. I also used it for the esc for a while. When I was doing that I zip tied it around the esc.
    I don't care for the RPM sensor, I don't know what it matters to know aside from giggles, lol.
    460, straightpipes, buried throttle, nuff said :D
    13,238
    It is my pleasure to help others who share the love of this truck. I just love to help those in need in general
    Jul 2012
    Mesa az
    400
    I knew it was gonna happen that you couldn't stand not being fast.
    Feb 2004
    5,697
    Quote Originally Posted by Wakesurfer98 View Post
    I think we all did haha.
