Results 1 to 16 of 16
    Jan 2014
    4
    Need help! can't tell if it's the motor or the board.
    So a friend crashed my alias. not too hard, but it was It was in the snow...I was upset to find that when I took it inside it was not binding to the remote. after calling traxxas and having them help me re connect the quad to the transmitter I found that the alias will no longer fly. all motors seem to be spinning fine. but it immediately flops over one way other. I can trim it but it still will not balance itself. could this be a motor issue? or have some of the electronics kicked the bucket. any help greatly appreciated! I'm gonna call traxxas again tomorrow.
    Dec 2013
    18
    its a motor more then likely.........
    Dec 2013
    192
    Have you tried calibrating the accelerometer? Look up procedure online from Traxxas. Try that see if it helps..
    Jan 2014
    4
    well I tried resetting the accelerometers, still flopping over. I'm pretty sure it must be the motors.
    seems like the most common problem for everyone. both the front props seem to start spinning but give out after a few seconds now. looks like I will e investing in a good amount if these motors. hopefully they come up with some upgrade along the way. I really love this thing. had flow. it a bunch with a hand full of violent crashes with no real damage at all. one broken gear spur , but that's it. I guess the motors are only gonna last so long.. I'm kinda used to that. I burn thru the motors on my blade qx all the time. thanks for the help
    RC Qualifier Charger Man's Avatar
    Oct 2008
    Kansas
    611
    Just make sure it is on a flat surface when you arm it, because if its at an angle when u arm it, it takes that as level and will flip over.
    115 mph Heavily Moddified Slash 4x4 on 6s
    Dec 2013
    192
    Also are you sure you have the props and motors in the right spots?
    A props wher A props go and B props where B props go. Same thing for the motors.. There are 2 clockwise and 2 counterclockwise.
    Saint Louis, MO
    498
    Mine did this and I had to do the resets and rebinding a few times and it works now
    Sent from my iPad using Tapatalk
    Jan 2014
    4
    I have definitely been arming it on the flat ground, and the props are all in the correct spots. I will try resetting it an rebinding it a few more times I guess. can't hurt
    Jan 2014
    4
    sorry for not posting this earlier, after rebinding the alias 3 times it worked fine. I've been having a blast with it. it's even taken some pretty crazy crashes and taken them in complete stride. I'm getting pretty into this thing and I just ordered a camera to get some FPV action.. thanks again for the help y'all.
    Feb 2014
    Hi flyingocti
    I got similiar problem and did the reset and rebind 10 times each..
    Problem:
    the front probs run fine
    the back wont level correct anymore
    explanation:
    i did fly nicely from the start indoor, we got it outside, and find a spot with no snow...
    but... the Wind took it for a drift and drop Down in the snow....
    after this, i wont level anymore.. everything is dry, but it got alot of snow inside.. :-(
    Should i buy a new receiver board og just the back motors? Or is there a trick beyond the reset, and rebind?
    Best regard
    TopDuck71
    Feb 2014
    Hi Group
    Hi
    I just got a answer from Traxas, saying that they do not have the "Main Circuit Board (RX/ESC) (Alias)" as a spare part.......
    And i need it so much :-/
    They are actually saying i must buy a new Alias, to get the Board! Total Bummer....
    /TopDuck
    Saint Louis, MO
    498
    Check online. I have seen them for sale.
    Dec 2013
    192
    Quote Originally Posted by TopDuck71 View Post
    Hi Group
    Hi
    /TopDuck
    Ebay has them.
    Feb 2014
    White Lake Mi 48386
    45
    Binding the Alias to the transmitter. instructions in the hand book. Very easy...
    Mar 2014
    25
    Hi Group
    Hi
    /TopDuck
    you can use traxxas electronic replacement program.. print the form and ship the board with the 20$ enclosed payment and they will ship you a new one... sending mine out did buy a spare from ebay sending bad one to have a backup
