Results 1 to 13 of 13
    illinois
    639
    Traxxas lipo charger
    Yes i know a lot of responses will be to get a faster charger, but for now I'm good with the traxxas wall lipo charger (as long as it works correctly).
    My question is I'm not sure if the charger or the battery is messing up. is there a way to figure out which one is messing up. Im charging a 2s spc 5000man and it seems to charge fine and when the one cell is fully charged the other stays red n will continue to do so the entire night if i let it. but if i unplug it and plug it back in, it stops charging and goes to a green light saying its fully charged.
    "Jedi Master"
    Oct 2013
    Thousand Oaks, CA
    473
    Do you have another lipo charger to test?
    Sent from my iPad using Tapatalk
    Go Traxxas, Team Associated, and Losi!
    illinois
    639
    nope - i was wondering if others had encountered the same thing with there wall charger. if not then most likely to me it'd be the battery then.
    Quote Originally Posted by Traxxasfreak61 View Post
    "Jedi Master"
    Oct 2013
    Thousand Oaks, CA
    473
    Does the battery act normally when you run it, and also try a friend's charger to see if it does the same thing.
    illinois
    639
    don't know of anyone else around that has an rc muchless a lipo charger - nearest track 2 1/2 hours away
    "Jedi Master"
    14,936
    Volt meter. Before blaming the battery, you MUST at least read the voltage after charge. I would hold off on using that charger again till you find out if its not doing its job. If the battery is bad, chances are the 5$ charger did it.
    Ya can't polish fertilizer...
    illinois
    639
    thanks i will pick up a volt meter
    "Jedi Master"
    illinois
    639
    Just bought a new duratrax lipo charger n a new spc 2S 6500 65C battery
    "Jedi Master"
    illinois
    639
    What r the odds the new charger balances the old battery back out
    "Jedi Master"
    14,936
    If the battery was not damaged by 1 cell being discharged too much, chances are pretty good. The battery has not swelled up has it?
    illinois
    639
    no swelling - it just didn't look like it was going to stop charging the one cell the light didn't turn green unless u unplugged it then plug it back in - haven't run it yet - so it shouldn't have overly discharged
    "Jedi Master"
    14,936
    Sounds like you are ready to go as soon as you check that the cells are balanced with a voltmeter, or on your new chargers screen 8)
    illinois
    639
    yep new charger is here and it charged up and balanced itself nicely.
    "Jedi Master"
