Thread: 1/16 mustang
    Sep 2011
    North Jersey
    90
    1/16 mustang
    How can I lower the car more than it already is it flips over way too easily on high speed runs.
    Drive it like you stole it
    Alma, Michigan
    12,314
    Is the preload backed off of the shock springs?
    Canton Georgia
    2,149
    If you are running pavement only you could do a 200mm conversion...
    Slash 4x4 LCG+(rolling)HCG, Slash 2wd(raptor)
    Sep 2011
    Iowa City, Iowa, USA
    4,361
    What's the 200 mm conversion?
    Sent from my SCH-R970 using Tapatalk
    Jun 2013
    LaConner, WA
    368
    Hr has 2 kits to lengthen the chassis to 1/10 touring car size. Carbon,$130 and alum,80-90$
    Jun 2013
    LaConner, WA
    368
    Wheel and suspension upgrades. As well as diff fluid. Swaybars...
    Quote Originally Posted by brianf337 View Post
    Jul 2013
    Pembroke, Ontario Canada
    207
    Are you running the stock spring preload setup? i also had this issue i found out the taking the preload off your springs lowers the ride height a lot. springs i am currently running 3.2 1/16 summit springs what a improvement(stock ones are just to soft)
    that being said i will be trying 3.2 rated springs up front and 4.3 in the rear. after all since i tried racing my 1/16 Mustang boss 302 i found a improvement now also take into account the surface you running on, what type of tires you need.
    since high speed iis what you said go for grippy tires like 1/10 sedans use. add some weight if you feel it will help.
    this is what i would do. it may not work for you Trail'N'Error till you get what you like. it may cost some cash.
    Jul 2013
    207
    Heres a video i found to inspire getting my setup. Where i found my set up: http://www.rctech.net/forum/micro-mi...ly-car-36.html
    http://youtu.be/WBAaXaLtiQU
    in my opinion this is how Traxxas should have set up the Mustang boss/fiesta. it be easy to get a drift and and high speed set up without traction rolling every corner when stock.
