Results 1 to 8 of 8
    Dec 2008
    suffolk England
    312
    non waterproof vxl
    just blown another vxl whilst using in puddles and water,these things are certainly not waterproof smoke and horrible smell coming out anyway:-
    I fancy going for the waterproof sidewinder sct 3800 combo
    as I run on 3s will I be disappointed
    if I have to go to2s that's ok,
    please advise
    I'm from rip off Britain
    Oct 2013
    511
    I never had a a problem with vxl in water but the sct system is great i love it so much i own 3 of them(rustler, p4de, and slash 4x4) and it will run 3s but watch ur temps and gearing. 2s u can usually run afew teeth higher than stock 3s usually a few teeth under but it has more power that stock for sure
    Just my 2 cents
    Lehi, Utah
    1,762
    Really!? I haven't had a problem with my vxl system at all. Is has been great in the wet. It's been through rivers and inches of snow no problem. Are you sure there wasn't something wrong with your system? Traxxas should replace it if it broke from water damage.
    Slash 4x4 built w/ RC4WD PRL RPM STRC TRX and MIP
    Jan 2014
    South Dakota
    215
    Have you considered a mm2? Its waterproof and you would be able to run 3s without having to even worry about temps. Although its pretty spendy. If money isn't an issue, I would go with that.
    Sent from my DROID RAZR using Tapatalk
    Dec 2008
    suffolk England
    312
    what motor would you recommend with mm2
    Quote Originally Posted by wwSome View Post
    Jan 2014
    South Dakota
    215
    I believe you can get the 2200 or 2650 combo from castle but for a slash that's kinda overkill. If you order separate you could get the 3800 or 2400. I would go for the 2400 for a 4x4 and you could run 4s if you wanted.
    Dec 2008
    suffolk England
    312
    Mm2 with 3800 would give me the option to go for 3s i suppose
    Feb 2010
    Indianapolis
    14,199
    I would pair it with the 2400 motor. I had mine geared 19/54 and it was quite nice! Good speed and plentg of low end grunt. I plan on getting another 2400 just not sure what esc I will pair with it.
