    Nov 2013
    North Jersey
    300
    New wheels slightly larger what size pinion should i go with?
    Stripped another hex so Im going 17mm
    I got the revolver wheels and decided on imex Baja wide 2.8 tires, they are slightly bigger than my trenchers so I want to go down in my pinion gear just not sure what size to go, im stock now
    I was thinking to drop to a 10t pinion any suggestions?
    Norfolk, va
    1,164
    Run it as is and see what your temps are. You might not even notice the loss of acceleration.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    Oct 2013
    511
    I second zepher's suggestion. Stock gearing is usually a fairly safe gearing. I would just see how it goes. The small difference in height will make a different but not much at all. Weight is going to rele be the deciding factor.
    Just my 2 cents
    Wales in the UK
    6,462
    If you run 3s I would gear down just to get some acceleration back dude but that's just me....peace
