Results 1 to 15 of 15
    Jan 2014
    78
    Best castle esc for MERV
    Which is the best between the 1/18 or would a 1/10 be better
    Jul 2012
    Yakima, Washington
    1,440
    The 1/18 is too small. I got the 1/10 scale SW3 and love it.
    Jan 2014
    78
    Does it slide right in and fit?
    Jan 2014
    78
    And also could I put in a 1/10 velioneon motor?
    Jan 2014
    78
    And also does it plug right in?
    Jul 2012
    Yakima, Washington
    1,440
    No it take some custom mounting. That is the downside.
    Also you have to solder on the traxxas connector. Everything else pugs right in.
    Jan 2014
    78
    Oh then i probaly wont get it
    Alma, Michigan
    12,314
    The only ESC that is going to be 100% plug and play is stock. Everything else is going to require some installation work.
    The Sidewinder 3 is a great ESC option for a 16th. I feel it is paired best with the stock V380 motor. Any 10th scale motor is going to raise the center of gravity making the RC handle a whole lot worse.
    Also, the motor does not plug right in... the motor has 3.5mm bullets and the ESC is equipped with 4mm bullets. There are adapter cables out there though.
    Dec 2013
    32
    I got the sidewinder 3 and I'm new to rc car but what I had to do to fit the sidewinder on the merv was easy and I know where to get the perfect fit connectors to make that esc a great compliment to the merv
    Jan 2014
    78
    Well i dont have a folding iron or anything like that
    Sep 2011
    Iowa City, Iowa, USA
    4,361
    You can get them for literally $2 at walmart. Soldering isnt that hard.
    Sent from my SCH-R970 using Tapatalk
    Apr 2010
    USA
    216
    Our hobby store will solder the connections on for around $7 or try a battery store if you don't want to solder yourself. For the SV3 I just dremeled (or you can file) off one of the brackets that holds the stock esc in and I just used 3M velcro to hold it in (I did go big block so that gives me a little more room to fit the ESC).
    Alma, Michigan
    12,314
    There are also adapters specific to this installation (Stock Traxxas V380 to the Sidewinder 3) on eBay.
    Slovenia
    322
    Just my 2 cents: Learn to solder, if you plan to stick with this hobby. It is not expensive nor difficult, but benefits are huge...
    Dec 2013
    WI
    745
    Quote Originally Posted by mtc777 View Post
    Yep, learning to solder is invaluable with this hobby. Check out some youtube vids that show you how. Flux is great too, you can almost solder blindfolded with that stuff.
