Results 1 to 4 of 4
Thread: Sloppy Steering
    Dec 2013
    Westwego, LA
    59
    Sloppy Steering
    My servo does not return to center after a turn left or right.
    This gets quite annoying when trying to do speed runs and quick accelerations when you have to fight the steering the whole time.
    Any suggestions on what can be done to fix this?
    And does the servo have the be a certain way in the car because after I dyed the chassis and such, I swapped the side the servo is on, not sure if it makes a change to the car or not.
    Oct 2013
    511
    Did u remove the servo horn when you removed the servo? And is the steering binding or simply turning one way?
    Just my 2 cents
    Jul 2013
    Connecticut
    851
    Check the servo itself or check the servo saver
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,511
    Most likely suspect is the servo saver but it can be any component in the steering linkage worn out or getting sloppy. You just have to inspect the steering system piece by piece and find what is worn out.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
