Results 1 to 8 of 8
    Feb 2014
    5
    12mph max speed?
    I've recently had my stock motor replaced under warranty (excess play in the bearing), it was less than a month old when it was replaced.
    Since getting it back it's felt much slower.
    Today I strapped my phone to it and a gps app reckons it's only going 14mph
    Any ideas? It's not in training mode, when I do that it's 7mph...
    Thanks!
    RC Turnbuckle Jr. Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,511
    Try recalibrating the radio to the ESC to ensure you are getting full throttle.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Feb 2014
    5
    Sorry, yeah I've tried that. Also I have two battery packs.
    I've made sure the cells have been cycled and fully charged.
    I wondered if the speed controller could be at fault?
    Mar 2004
    N. Idaho... Da Sticks!
    7,614
    Did you set the gear mesh too tight? How much backlash do you have?
    Feb 2014
    5
    Mesh seems fine. Is there a way I can test the ESC without a new motor? Voltage?
    130
    swap it out with a brushless pal and you will thank us
    Jan 2014
    70
    How's your battery? You can't check the output of the ESC with a voltmeter, but you should be able to check your battery output.
    The other thing to note is that the calculated maximum speed for the stock gearing and tires is around 15 mph. Look at the gearing chart on page 21 of the manual. They show that the ratio needed for 30mph is 9.45 and that the stock ratio is 19.69. The stock gearing is 47% lower than their 30mph setup. This would make the stock speed 30mph * 0.47 = 14.39mph
    Feb 2014
    5
    New motor and now I get 18.9 mph on my gps app!!
