    Apr 2013
    Portland, OR
    1,389
    Lipo cells out of balance after discharge
    Hey guys,
    I couldn't find where this question had been asked before, but I'm sure it has, so sorry in advance for asking a repeat question.
    I'm running 6500 & 5000 mah 2S Lipo batteries in my Slash 4x4. Once LVC is reached and I put the batteries on the charger, I see that there seems to be a large amount of variance in the volts per cell of each of the two cells. For example at full charge (I always balance charge) each cell is at 4.2 volts per cell but after discharge it is not uncommon for the charger to read a difference of as much as .3 volts per cell difference between the two (3.55 vpc on cell 1 and 3.25 vpc on cell 2). Usually the difference is much less than that, usually in the .1 - .15 volt per cell area, but I'm wondering if that variance is normal or something I should be keeping an eye on.
    So my question is what is a normal difference in volts per cell between cells after discharge?
    Some possibly relevant information:
    -I always balance charge, no exceptions
    -The batteries have never been hot or even warm to the touch after discharge
    -The batteries have always been stored at proper voltage
    -The batteries are in good condition and have not had any major trauma
    -One battery is 2 months old, the other is 2 weeks old
    -I only charge at 4amps (less than 1C)
    Any input would be helpful. Thanks!
    Alma, Michigan
    12,314
    The variance is normal... and is the reason why balance charging every time is important.
    12,490
    Best to contact the manufacturer of the batteries.
    20,070
    As said, you should contact the dealer.
    However, looking at your cell voltages, it is very obvious that you have over-discharged and therefore damaged the packs.
    Sorry.
    Alt-248 on the number pad =
