    Sep 2013
    Waterbury CT
    76
    Dusty Covers Issue
    hello,
    Is anyone running a Dustycovers shield with a dewalt?
    When I run mine the dewalt gets very hot! I dont have a temp gun, But I can barely touch it after I run a pair of lipos through it. I never crawl in high gear, and when i run without the dusty cover temp seems to be ok.
    Jul 2013
    78
    Any motor will be hotter with shroud on, even brushless. It may not seem like much of a difference, but it reduce airflow significantly. I use it often with zipper open. If you can't hold your hand on motor for more than than 1-2 seconds it is very bad for motor.
    kansas
    8,677
    I've unzipped during winter snow runs to keep the temps down. That is why I like the Dusty (zipper)...
    20,111
    Quote Originally Posted by ddepedro View Post
    hello,
    What gearing are you using?
    Alt-248 on the number pad =
    Mar 2013
    Bellevue, NE
    102
    Put a Outerwears on mine and my 775 and Dewalt didn't like the added heat even when it was 8f out. Dewalt I was running 18t pinion which is a tad high.
    1/10 Summit & 1/10 E-Slayer
    Sep 2013
    Waterbury CT
    76
    Im running a 17t pinion and stock spur, but whats the point of having it on if its unzippered? Does it still keep the snow and mud out??
    Thanks
    RC Champion soundmaster's Avatar
    2,855
    I also bought the Dusty Motors Shroud but used it only one time because 775 Motor and ESC are getting too hot for my liking.
