Thread: Confused
    Apr 2013
    Wisconsin
    78
    Confused
    Could someone explain the use of these?
    http://www.amain.com/product_info.ph...Hub-Set-Blue-4
    Alma, Michigan
    12,314
    They go on the axle shaft for use with Traxxas 17mm rims.
    Wellsburg, IA
    59
    Yep, what Jimmie said. I would recommend them, 17mm hex wheels are alot more durable, especially if you have already or plan to go brushless, plus they will open up a whole new set of tire options, excellent choice if you are going to race your E-Maxx.
    EMaxx 3903 / Revo 3.3 5309 / Slash 2wd 58034
    Apr 2013
    Wisconsin
    78
    So these tires — http://prolineracing.com/tires/trenc...tires-mounted/ — wont fit on my stock e-maxx but they would fit on those upgrade wheel hubs because they are 17mm?
    Alma, Michigan
    12,314
    Yes.
    However, there are two reasons I can think of right now as to why not to buy Traxxas hexes for that rim:
    1) The Traxxas spline is not needed for that rim.
    2) Traxxas hex's are known to get sloppy over time, requiring either replacement or modification.
    HPI makes a hex set that is 100% bolt on:
    http://www.ebay.com/itm/NEW-HPI-SAVA...item58ad774074
    Apr 2013
    Wisconsin
    78
    Wait so what you are saying is that I shouldnt get those Pro-Line pre-mount trenchers because they WILL NOT fit on my stock E-Maxx?
    Alma, Michigan
    12,314
    I am not saying to not get them.
    If you want them, they will fit with minimal work. The first thing you will need is a 17mm hex set to match the rims. The hexes you linked to will work, but they will also get sloppy after a while. The HPI hex set I linked to solves that.
    Apr 2013
    Wisconsin
    78
    ok I understand. Thanks for your help and sorry if I was a little clueless.
