Results 1 to 25 of 25
    Mar 2014
    13
    New esc cogging very bad?? and no reverse...
    I have the stock motor and replaced my esc with a sv3 becuz of the cogging I would get on full throttle so u thought my esc was bad anyways I jnstalled the sv3 and I did the start up procedure but my reverse doesnt work and foward wont go anywhere it just twitches like its cogging very bad. It wont even spin the tires if I pick it up??
    Sep 2011
    Iowa City, Iowa, USA
    4,346
    Is the drivetrain binding?
    Alma, Michigan
    12,314
    Has the motor ever been overheated?
    Mar 2014
    13
    Well I believe it over heated it was cogging alot so I thought my esc was bad. It worked but if I gave it full throttle it would jitter than if I gave it a push start it would run fine. But from a dead stop it seemed like it could nt handle the current drop. I did drop the motor today in the garage idk if that damaged it??
    Mar 2014
    13
    No binding it was running fine for a bit so idk if I didnt program esc correct? Its a brand new sidewinder v3
    Alma, Michigan
    12,314
    Overheating damaged the magnets within the motor... sounds like that was the problem, the overheating, and not the ESC.
    Sep 2011
    4,346
    I have a tekin motor that overheated and does this. I measured the temp at 265. I don't think that motor could even move a merv anymore.
    Slovenia
    321
    Overheated magnets would hardly cause cogging, the motor would just loose power. Cogging usually means that one wire is broken or connector has bad contact
    Alma, Michigan
    12,314
    It is very possible that over heated magnets could cause cogging.
    Mar 2014
    13
    Well is would cog only from a complete stop. So it would still run just cog from a dead stop so I got a new esc and its not even like it was I have no reverse and it wont even go forward ill have to check my connections...
    Mar 2014
    13
    so i found that the wires had a coating on them and was not conducting at all... so i ran a wire brush thru it and not i have continuity
    Alma, Michigan
    12,314
    Stiff motor wires are a part of the winding. They should not be cut and then soldered or modified in any way. This will disrupt how they function... and they are supposed to have this protective coating on them.
    Changing connectors is done by de-soldering and then resoldering them.
    Most of the time a new V380 is available on eBay for about $30.
    Jan 2005
    Nuclear Power Plant drainage ditch
    2,714
    Epoxy coated wires are a huge pain to solder. They use them in headphones which I repair. You have to remove the coating before they will take solder.
    All those who believe psychokinesis raise my hand
    Mar 2014
    13
    I'm an electrical technician where I work and I'm aware of how to change connectors but problem was the wire broke that's whys its much shorter than the rest.. the other 2 leads were tinned and I de-soldered those. Ive just never seen a bare wire not have continuity... now that I know whats going on I hope later today when I test it its fine. Ill let you guys know
    Mar 2014
    13
    I'm just trying to get the most out of the motor before I go and buy a new one...
    Alma, Michigan
    12,314
    Good to know that you have some knowledge of what you are dealing with.
    I wonder if the other two should be shortened as much as the one that broke... if timing is effected.
    Slovenia
    321
    ...as I said
    Mar 2014
    13
    Quote Originally Posted by mtc777 View Post
    ...as I said
    Give yourself a pat on the back!
    idk about that?? I think ill shorten the other 2 leads up just so there at least the same length..
    Jan 2005
    2,714
    Quote Originally Posted by merv1k View Post
    I wouldn't shorten them. The difference in timing will be near immeasurable.
    Slovenia
    321
    I just did....twice
    Mar 2014
    13
    Quote Originally Posted by Buzzforbrains View Post
    That's what I thought but since I was having issues with continuity I want to make sure the connection is solid so I want to clean off the epoxy and re-crimp a butt splice connector on it and i think it should work with no issues.. Ill let you guys know tmrw morning how it went.
    Slovenia
    321
    But you can shorten the wires of the ESC, right ?
    Now please explain the logic behind that.
    Mar 2014
    13
    So it worked out I have no cogging but still no reverse.. Ill have to make sure my settings are correct...
    Jan 2005
    2,714
    Sure, you can shorten any of them if you want. But having one wire 1" longer will not throw off the timing. The time it takes the signal through 1" less or more of wire is near immeasurable.
    Mar 2014
    13
    Its measurable just need a meter that can read in mili to ohms.
    Last edited by cooleocool; 04-02-2014 at 09:10 AM. Reason: Language filter was tripped.
