    Oct 2013
    112
    possible seized trx.15
    hello, my older brothers have a 1st generation nitro 4 tec with an old .15 . i believe its siezed because last time i was at there house the engine wouldnt turn over and i couldnt turn the flywheel. but anyways its been sitting for many years and i might be trying to repair it soon. if the engine is siezed what should i do. is there a way to unsieze it like putting oil or wd40 in the glowplug hole and let it sit. or should i buy a new piston sleeve and clean the original piston? we dont have much money to buy a new engine.
    Riverton Utah
    5,642
    I'd spray some WD-40 into the engine, and let it sit for awhile. Try seeing if it turns over after that. Good luck.
    Is owning 27 RC's too many? No way!
    Jun 2013
    Tx
    38
    I have the same car and mine locked up after running it for about 15min because it has Ben sitting for about a year or so. I just pulled it apart and cleaned it with wd40 and put it back together and worked just fine. Intill I throw a connecting rod, which locks it up too
    Oct 2013
    112
    Yea I put afterun oil in the crank case and within 5 minutes it was unsiezed and smooth turning
