Results 1 to 14 of 14
    Sep 2013
    24
    Proline 2.8 Trenchers for Stampede on Telluride
    I will be using the Telluride for trails and some bashing. I have upgraded to brushless motor and slipper clutch. I have seen a few people put these wheels and tires on and I am wondering if they are a direct bolt on or if suspension mods are needed? How do you like them? Do they affect steering at all? Did you change your gearing and if so how much. Do I need different offset for the front and back.
    I was also considering the Proline 2.2 Trencher but I was not sure if I would see much benefit from that tire compared to stock. Any opinions?
    Feb 2014
    457
    Had these on my telly, they did rub the body a tiny bit, when suspension was compressed. Steering is definately a little slower, i'd pick up a trx 2075 servo from the pede.
    Apr 2014
    23
    The 2.2 Trenchers are a big improvement over the stock tires. I just upgraded mine last week and they are great all round tire.
    Mar 2014
    17
    Great choice
    Sep 2013
    24
    Waiting for my 2.2 Badlands to arrive.
    Mar 2013
    New Hampshire
    755
    Remember if you get them you will need to get two sets of backs or two sets of fronts because if u get back and fronts the fronts will stick out. I suggest getting fronts to widen the truck.
    Edit: they will also rub against the body a lot when the suspension is compressed so you will have to cut the fenders or raise the body.
    And we thought toy grade RC's where cool...
    Sep 2013
    24
    I just put the 2.2 Badlands on an now I am getting a clicking sound at times. I am running a Velineon with 12 tooth pinion and a slipper clutch. Is that the gear skipping now that I have more traction? It does it randomly on launch and landings, backing up. I run the slipper pretty tight. Should I back it off some? How much?
    Mar 2013
    New Hampshire
    755
    That's probably the center drive shaft. Since its plastic it will skip if you put to much power through it. If you get an aluminum one this won't happen. Try not to skip it too much or you will strip it.
    On my bone stock telly it does it on pavement only so your new tires probably are giving you more traction to skip the drive shaft.
    Sep 2013
    24
    Ok , thanks. Never thought of that one. I guess I'll just run it for now.
    May 2014
    17
    I put stampede wheels on my telly and the original high stall clutch kept backing out. When i put the stock tires backk on its fine not sure why yet but plan to upgrade the clutch
    RC Qualifier Devon_4's Avatar
    May 2014
    BC, Canada
    304
    Proline makes 2.2" trenchers for the slash and other vehicles and since the telluride uses slash tires, they shouldn't rub or anything.
    May 2014
    39
    I have the 2.2/3 pro line trenchers on my telly and they don't rub at all. They work pretty good :-)
    130
    im running the 2.8 trenchers and the new f11 wheels with slash arms and it handles great
    it wheelies all over the place now with the castle creations brushless and the stampede slipper
    May 2014
    39
    Here's mine with 2.8 trenchers and pede long arm conversion :-)
    [IMG][/IMG]
