    Feb 2014
    10
    Starting my slash
    Hey everyone so I've had my truck for about 2 months now and it's awesome but whenever I go to start it up it take a good 20-30 seconds or so with about 4-5 seconds of priming. After I get it started it runs like a champ. is that normal or what?
    Feb 2014
    49
    That's how it always is for me. I usually overkill the after run oil, so its runs a little funky for the first few seconds then its good. The reason it doesn't just start right up is probably because the glow plug needs a few seconds to get the fuel hot enough to combust. Its not like a gas motor that runs on spark, this fuel runs off of heat and compression.
    13,530
    The glow plug should glow nice and hot almost immediately. A good tune will get it to start right away--for me, most of the time it takes quite a few pulls to get it started when cold.
    Feb 2014
    10
    The glow plug does light up and it's tuned vary nicely so idk but I noticed it takes a while to suck fuel through the lines is that normal?
    13,530
    It doesn't suck the fuel it gets pushed by the exhaust, hence the pressure line from the pipe to the tank.
    Feb 2014
    10
    Ha oh ok well either way it takes a while to make its way through the line normal or not?
