Results 1 to 15 of 15
    Oct 2013
    218
    Mamba monster esc power switch issue?
    Hi!
    I got a new emaxx brushless non waterproof so i guess it is a mm1.
    On the second use the car will not turn off, its still on when it switched off, and when i turn the switch to on again then the car restart and give some bipp and shows its ready to drive.
    What could i do with that?
    Anyone that have this problem?
    I just open the switch and looking for problems, couldnt find the problem and now after i install it again it works fine, strange..
    Brookline, NH
    1,229
    Those little switchs on the mmm escs are notorious for that. One of mine just quit working too.
    Dec 2013
    Starr County, Texas
    683
    yes those switches are cheap quality, on my MM2 it started shorting out with in 1 week of usage. I just bypassed it by cutting it off and connecting both ends together, that way a soon as i plug the battery, it starts right up. Was getting tired of trying to find the switch everytime anyways, I have no mount the switch was just laying there
    <P4de VXL|Castle 3800kv|MM2|MIP|STRC|Proline|SPC>
    Dec 2006
    camillus, ny
    2,850
    Every castle product i’ve owned has had a switch go bad. For my mmm2 its only a matter of time.
    Man i need more than 50 characters.
    7,264
    Do you guys turn on/off the switch every run? I leave mine on and just unplug the battery to turn it off.
    Dec 2006
    camillus, ny
    2,850
    If the switch on my model works then i usually use it.
    kansas
    8,677
    leave it on........idkwhy just do....
    7,264
    another way to do is to solder them wires together as short as inside the case to eliminate the switch, but leaving it on will be your first option.
    Eastern Shore, Maryland
    3,187
    Go to RadioShack, get/install a SPST switch to your MM1 or MM2, and you will end any future switch problems.
    Oct 2013
    218
    Where do you order that switch? :-)
    Its works fine now but last time i use it i hear suddently the esc restart and beep when the truck standing still.
    Wierd that a big company like castle that make so good esc and motors dont make the power switch correct.
    What is realy wrong inside the stock switch? Everything seems to be fine inside the switch.
    Oct 2013
    218
    The easy way is to cut it of and dont use the switch since so many in here have remove it, i think is a reason for that they deliver it with power switch? I have owned a rc boat with orion esc on 4s and that came without power switch out of the box. Everytime i plug it in the boat was turned on, it was deans connector and it looks like a firework out of the connector when i plugged in the lipo battery.
    Isnt it bad to plug in volt on a thing before its turned off? Of course it dosnt do anything since so many in here have done that to the esc, maby its worse when we handle more volt than a couple of lipo battery.
    I think it is strange that castle dosnt came with a solution or that they dont deliver it without powerswitch when they not could make switches that works longer than 15 minutes
    Jan 2015
    37
    I was running it hard-wired for a while and decided I want to bring back a power switch...I see a slew of options for replacements, but I'm not sure which ones will be a good replacement...don't want to create a new problem & these ESCs aren't cheap...I know this is an ancient thread but I'm hoping one of y'all can tell me what sort of specs I need to look for in a replacement switch. For example, would something like this work: http://clipitto.com/DNyqW6 ? It's for the MXL-6S (E-Revo Brushless w/6S). Thanks!
    3,187
    That's not a good switch to use for use with a MXL-6, MM1, or a MM2. I'm out in the field right now, but when I get home tonight I'll hook you up.
    3,187
    You want either a Micro Slide Switch or a Miniature Mini Toggle Switch SPST. I looked on Amazon and they have both. If it were me (it's what I used with my Emaxx's MM2) I'd go with a SPST Mini Toggle switch. In Amazon it's the one rated at 3a/250v or 6a/125v. If you do use that switch you will want to make a mount for it. When I get home I'll post some pictures for you. I posted pictures here a long time ago, but they fell victim to the greed of PhotoBucket.
    3,187
    Here yo go. This is a picture of how I did it to my Emaxx. I did something similar to my friends ERevo.
