Results 1 to 16 of 16
    Mar 2014
    15
    Blast vxl-3s upgrade
    Hello alls
    i make vxl-3s and velineon 3500 motor upgade
    blast is very fast with nimh and lipo
    my problem is
    forward and reverse are inverted on remote
    why? possible to change motor rotation?
    need change in esc?
    thanx for help
    Regards
    RC Qualifier CrawlinMike's Avatar
    Mar 2009
    Jacksonville, Il
    602
    Just switch any of the two motor wires. They don't have to be on matching colors
    Lock, Stomp, and Steer. No Fear
    Mar 2014
    15
    thanks
    i will try
    It s work. Thanks
    New problem
    Tested with nimh 7.2, 8,4 and lipo 2s
    But in lipo mode blast si transformed in sub marine
    Impossible to press at Max the remote
    My blast (return. Flip. Turn) and flow.
    Prop it s original
    Thankx for help
    Regards
    Mar 2009
    Jacksonville, Il
    602
    Ive had a blast brushless. On lipo as well. I don't recommend nimh as they add too much weight. You will probably have to adjust the vertical angle of the prop. I had original prop. The idea is to ease it up to speed and no sudden throttle or steering. It will rise and plane over the water after it stops cavitating at the prop. Adjusting the prop angle will help prevent too much cavitation.
    Mar 2014
    15
    I found this on forum
    http://traxxas.com/forums/showthread...s-Blast-advice
    About you no need two skegs for stabilisation?
    My prop angle is at lower
    Thanks
    Or two turn fin
    Mar 2009
    Jacksonville, Il
    602
    I don't believe English is your first language. But I'm working with you much as I can. I don't believe a lower "skeg" rudder support is necessary. I think it would be too much trouble. I'm sure there is flex going on in the water. But most of the stabilization problem with quick throttle is the rotating mass of the vxl motor.
    I made a stabilizer fin but just this small piece of metal weighed it down too much to be able to get to "plane" speed. If a plastic one were made it would work I'm sure to help steering control.
    Mar 2014
    15
    Thanks for help
    I m not english
    Sorry for the technik word
    Where i CAN buy this for my blast?
    Regards
    Mar 2009
    Jacksonville, Il
    602
    I'm sorry. This is a part I made myself. I make many custom parts for boats and cars. Where are you from? I deal with rc brothers all over the world. Thanks
    Mar 2014
    15
    From France
    Possible with this
    http://www.ebay.fr/itm/ePacket-to-US...item3381e5ec67
    Or
    http://www.ebay.fr/itm/ePacket-to-US...item4ac438b0e1
    Or
    http://www.ebay.fr/itm/CNC-Turn-Fin-...item3381e5f190
    There is 3 differente size
    From you, better for my blast with my motor
    Thanks for your help
    Traxxas Marshal
    Mar 2003
    Wherever the road takes me.
    37,489
    The Traxxas Blast is 603mm long, so the first set you linked to should work for a boat this size (they're designed for boats 500-800mm in length). The last two pairs of turn fins you posted will be too large.
    Mar 2014
    15
    yes i see that but on CrawlinMike picture the turn fin appear more longer than 40mn (about prop support longer)
    60mn for him i think
    Traxxas Marshal
    Mar 2003
    37,489
    Quote Originally Posted by Twm View Post
    Yes, but he noted that "this small piece of metal weighed it down too much to be able to get to "plane" speed." The fin he made was much too large for a boat of this size. Turn fins need to be properly sized for the boat, otherwise they will create too much drag and hinder performance.
    Mar 2014
    15
    buyed
    thanks for all
    Traxxas Marshal
    Mar 2003
    37,489
    You're welcome. I hope they work out well for you.
    Mar 2014
    15
    Turn Fins received this day
    Traxxas Marshal
    Mar 2003
    37,489
    Great, how do they look?
