    Old Saybrrok, CT
    17
    Rustler VXL no throttle
    So I just put my VXL motor and speed control back in my Rustler! Yesterday I was doin a few speed runs, all seemed fine! Then today it just stopped running and the ESC was blinking red, which means low voltage. So when I got home I plugged in my 3S LiPo and saw it wasn't even down to 4 volts per cell but I let it charge to capacity anyway when it was done I plugged it into my rustler the red light blinked at first then I got it to solid green. The steering works but when I pull the throttle the like blinks but it just won't go! Any thoughts? Any input would be welcome! Thanks.
    Old Saybrrok, CT
    17
    Does anyone have any thoughts? I could really use the help!
    Dec 2013
    101
    I would check your throttle trim
    Mar 2014
    Ghent - Belgium
    350
    loose connection?
    Dec 2013
    WI
    745
    I had this problem with my VXL-3s also. It kept going into LV mode for no reason... then sometimes I would lose forward, but still have reverse. Traxxas ended up replacing it.
    Does it work if you turn the LV off and run it in NiMH mode?
    If so you could just run it with the LV off and use an external low voltage alarm.
    Bashin' n' crashin'
    37
    Quote Originally Posted by TRX MERV View Post
    I too would recomend tweeking the throttle trim.
