Results 1 to 10 of 10
    Sep 2012
    Toronto
    102
    Lightbulb Alias - Battery falls out?!
    Battery falls out?!
    Here's an easy way to fix this!
    Wrap the battery with duck tape 2-3 times, not too tight!
    Leave about 1cm - 0.4 inch extra tape for an easy pull out.
    Hope it helps!
    20,527
    Looks more like packing tape than duct tape.
    Alt-248 on the number pad =
    Sep 2012
    Toronto
    102
    You might be right!
    What I've used is thicker than packing tape but thinner than duck tape!
    You can use any type of tape you want / have. Just make sure the battery doesn't fall off by itself and also for you is easy too pull it out!
    20,527
    Either way, the tape make it easier to remove the battery without pulling on the wires. Thanks.
    Feb 2014
    130
    I find it odd that you would worry about the battery falling out. Mine seem very snug. I wonder if the batteries compress with long use? I have six, so none have a huge amount of flights on them.
    20,527
    Mine got loose enough to slide back and forth due to impact. I used painter's tape and frog tape (blue and green) to minimize the movement as well as to differentiate between batteries for our blue and green Aliai.
    Sep 2012
    Toronto
    102
    Mine too. After every fly / land, I had to push it back, sometimes almost half of it was out.
    Anyway, this fixed my issue and now is a lot easier to pull it out due the extra tape.
    Feb 2014
    130
    Impact. Okay, now that's something different right there.
    I may be a wuss flier, but at least I don't crash.
    Sep 2012
    Toronto
    102
    Everybody tries to stay away from crashes or other hard impacts but when is too windy or you just got your first quad-copter and you're learning to fly is not easy to avoid crashes!
    I hate the wind, especially when is pushing my quad away and I can't control it at all so I have to drop it.
    I leave in a city where; high-ways, lakes, building or other private properties, are very close.
    Oct 2013
    Norwalk, OH
    65
    The way I see it, the battery won't shift while the Alias is airborne. After an unexpected impact, have a look and if necessary, reset it.
