Page 2 of 12 FirstFirst 1234 ... LastLast
Results 41 to 80 of 474
Thread: P4de build
  1. #41
    Jul 2014
    Penticton, BC
    96
    I just got a pede a couple weeks ago, new version with the 4 pole motor. I installed the sway bars with the shock guards on, just need to swap out the ball studs on the sway bars with the hollow ball mounts. The same ones the shocks use on the bottom. They are the same width of the spacer that is in the guards. I just got the rod end kit number 5525. 4 or 6 of the ends have the correct size hollow ball mount.
  2. #42
    Jun 2014
    Kansas
    3,013
    Yea they will work with the stock arms. I have proline protrac arms all around which has more holes. And my shocks are on the far outside holes. Which won't line up with the guards. Which I shoulda looked at before I posted. They are out there so my traxxas steal drive shafts will work better. If I bring the shocks in more which will raise the truck the shafts are barely in. I do have teknos shafts and xo-1 carriers on the way so maybe I can raise it alittle again
  3. #43
    May 2013
    Erie, PA
    719
    Quote Originally Posted by Darrath View Post
    Same route I went when installing the sway bars. I have always disliked ball studs.
    I also find that the shock guards provide added protection for the expensive powerstrokes. There are some pretty deep scratches in the guards, so I would saw they do something, especially the terrian where I bash...
    The message above or below may or may not be true
  4. #44
    Jul 2014
    Penticton, BC
    96
    Indeed, I am definitely keeping the guards.. Deep scratches in mine as well, and I really don't think I'm bashing it too insane...
  5. #45
    May 2014
    Vancouver, Canada
    88
    I just got tekno big bone center shaft. How much play should be in it. If none at all since those rubber washers are there
    How is the big bone center shaft? I have a rattling coming from the stock one (sounds chains rattling) and thought maybe switch out to this.
    Stampede 4x4 - 1/16 E.Revo - Bomber & SCX10 - TT02
  6. #46
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by woody131 View Post
    Haven't ran it much. But it's much more quiet than stock. Only because there's no play in it like the stock one.
  7. #47
    Jun 2014
    Kansas
    3,013
    Yes got my xo1 carriers,hexs. And tekno drive shafts all around. Hobbywing esc with program card
    Now I'm waiting on xo1 stub axles and my motor.
    Can't wait.
  8. #48
    Wales in the UK
    6,462
    Nice parts haul dude your truck is a sick beast......peace
  9. #49
    Jun 2014
    Kansas
    3,013
    Well I did the tekno/xo1 hybrid thanks to humayrayakongkinaon for the idea. Haven't ran it yet. Just put the rears on tonight. Letting the lock tight dry
  10. #50
    Feb 2014
    457
    What's the advantage of that setup vs say just teknos?
  11. #51
    7,264
    Quote Originally Posted by fls4 View Post
    the extra width and the dust boots keeps the dirt off yet the joints are well lubricated.
  12. #52
    Jun 2014
    Kansas
    3,013
    And the boots keeps the pin in also as the bearing would if you used the regular tekno bearings and carriers.
  13. #53
    Aug 2012
    Illinois
    22
    What motor did you end up going with ?
  14. #54
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by Gtp786 View Post
    The 2650kv one for now.
    Ok so it's finally here. So now I need a pinion. What gear should I start with 20,21. It'll be hooked to the hobbywing esc but only running 2s for now
  15. #55
    RC Champion soundmaster's Avatar
    2,858
    How much Top Speed do you want?
  16. #56
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by soundmaster View Post
    Good question. 35-45
  17. #57
    2,858
    With 20/54 and Stock Talons on 2s with 2650KV you'll get about 35 mph.
    I geared mine 14/54 running on 3s with 2400KV and get about the same speed. Enough for Bashing, but if I want really crazy tricks I put in 4s, but is almost uncontrollable.
  18. #58
    Jun 2014
    Kansas
    3,013
    Ok I got trenchers mounted on revolvers
  19. #59
    2,858
    Haha same as I 17mm Rules
    So you'll get around 37 mph. More if you didn't tape them due to ballooning.
    EDIT: I think 21T pinion is max. with 54T Spur according to gearing chart manual page 24.
  20. #60
    Jun 2014
    Kansas
    3,013
    Yea eventually I'll do 3s. I don't think ill touch 4s. How you figure up the speeds with gearing and size of motor
  21. #61
    2,858
    Yes 3s is more than enough. I only use 4s for crazy tricks like double backflips and so on. But it is really ridiculous.
    Here you can calculate you top speed.
    http://scriptasylum.com/rc_speed/top_speed.html
  22. #62
    Jun 2014
    Kansas
    3,013
    Thanks. They need to do an update
  23. #63
    2,858
    Very helpful and accurate tool.
  24. #64
    Aug 2012
    Illinois
    22
    Nice choice on the motor you might wanna pick up some smaller pinions. You might have cogging issues running a hi tooth pinion on 2s and I don't know what battery packs your running but make sure there hi C rating these castle system are power hungry and will help smooth out the cogging.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  25. #65
    2,858
    +1. Better higher Voltage and smaller Pinion. I run my Castle 1415 2400 kv with 14/68 on 4s in my Summit with very little cogging. No problem to crawl with that Motor
  26. #66
    Jun 2014
    Kansas
    3,013
    Well it's not the castle motor. It's the that looks identical but way cheaper. Someone on here has bought one or a few and was impressed with it. So I'm gonna try it out.
  27. #67
    Jun 2014
    Kansas
    3,013
    What kinda plugs are these. Anyone know
  28. #68
    7,264
    they fit directly to MM/MM2 ESC so its 6.5mm
    that motor is a monster and load of torque dude
    here's my motor collection, 2 on left are castle the rest overseas
    2200kv,2x 2650kv, 4300kv, 5200kv, 3900kv.
  29. #69
    Aug 2012
    Illinois
    22
    Nice my advice still stands the same unless you don't mind cogging do you know the manufacturer of the motor? Just curious haven't been on the forums in over a year.
  30. #70
    Jun 2014
    Kansas
    3,013
    Aww, thanks so you have one also. Ok so I guess I have to 6.5 mm female ends then. Since I don't have a castle esc
  31. #71
    7,264
    yep I got two of these motor and 3 with other KV. so far I got my Rally GT8 up to 84MPH.
  32. #72
    7,264
    do you know the manufacturer of the motor? Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    http://www.amazon.com/Neewer-Sensorl...ds=neewer+2650
  33. #73
    Aug 2012
    Illinois
    22
    Wow nice find guys for 40 bucks I'm gunna have try this out
  34. #74
    Jun 2014
    Kansas
    3,013
    I just searched 4068 2650kv and these and a few others popped up they are cheap
  35. #75
    7,264
    yeah your gonna need 6.5mm female and solder to your SC8 and your ESC is more than enough to feed that motor, plenty fast on 3s insane speed on 4s, I know you wont touch 4s now but later on you will be itching to try lol. I run 4s with my P4de on street run only with XO-1 wheels/tires geared 15/52 but that was before I got this motor.
  36. #76
    Jun 2014
    Kansas
    3,013
    Can I shorten the esc wires if need that goes to the motor without any problems.
  37. #77
    Jun 2014
    Kansas
    3,013
    Man I need to read this whole last page again. I missed a lot of things being said. Humayrayakongkinaon lol your the one that I seen that got this motor and compared it to the castle one. I'm just now seeing your pic of motors. Geez. Let's see first the tekno xo1 hybrid now the motor.
  38. #78
    7,264
    Lol, you probably used to seeing my avatar with my rally GT8. Yes you can cut the esc wire.
  39. #79
    Jun 2014
    Kansas
    3,013
    Yea that's prob it the avatar. I see so many things on here I forget who did what to what. I'm glad I went with the 2650kv though. There's little to no room for the esc
    Either here or
    Here
  40. #80
    7,264
    Put it closer to servo, you can make a aluminum plate and use the two screws holding the servo.
