Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 321 to 360 of 474
Thread: P4de build
  1. #321
    Jul 2014
    Shelbyville KY
    142
    Can you buy them already mounted ? I hate mounting them myself (too lazy and don't know how to do it might be better to say) from what I've read on here they are a firm tire that doesn't balloon as much or is that only if you mount them yourself ?
    MJB
  2. #322
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by baughler10 View Post
    Unfortunately they aren't available premounted. I'm sure after they sell a lot of them they'll start having premounted options. And other wheels available with 17mm. It's not the tire that's firm. I pulled the cell out and they are as soft as the trenchers and mashers. It's the cell itself that makes the tire firm. You can probably call proline and ask if there's a way they can mount them for you. Personally I prefer to mount them myself.
  3. #323
    Jul 2014
    Shelbyville KY
    142
    I'm just delaying the inevitable LOL - I need to mount a set myself. The Swampers will be my first ...
    MJB
  4. #324
    Jun 2014
    Kansas
    3,013
    Lol. I still need to mount mine. Cant do anything anyways since I'm waiting on my esc replacement and another male spline
  5. #325
    Jun 2014
    Kansas
    3,013
    Ok so after waiting on replacement esc, rebuild diffs, installed new rx with new tx. Axles, front bumper I finally got my wheels mounted and tryed them out.
    Modified rustler axles to work with stock length axles.
    Here's new rx/tx
    New bumper it's wide
    Compared to old bumper
    So after running the new wheels and tires. There is slight ballooning without taping them. That's me doing speed runs up and down the street. If you pick truck up and hold it in air well then there's ballooning. I like them how they are without tape. Their not pizza cutters like trenchers or mashers are without tape. But it's more with the closed cells that came with these tires.
  6. #326
    Jun 2014
    233
    What is the MIP part # for the longer CVD? Those would come in handy if I ever install longer a-arms.
  7. #327
    Jun 2014
    233
    And HOLY BUMPER BATMAN! Just noticed the difference! lol Are the tires rubbing it?
  8. #328
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by stillsmokin875 View Post
    I didn't notice. I'll have to look more at it or try to listen for it while in a turn
    Pat number 11105 is for the protrac arms if you already have the x duties
  9. #329
    Wales in the UK
    6,462
    The trucks looking better every time I see it bro keep up the awesome work...peace
  10. #330
    Jun 2014
    Kansas
    3,013
    Thanks bro. Well I finally managed to strip the servo gears. Time for something powerful I think it had something to do with the new rx I got. It has the avc option and I turned it on. Was doing pretty good with it. But I think when in got on the 2 right side wheels it kicked the steering to the right to get it back on all 4 wheels but then I think. I did the same thing with my old rx and tx. And I didn't adjust my strc servo saver since if put it in. So either it had enough or something else went wrong. So I have 2 options. Either do what humayrayakongkinaon has to offer with metal gears inside a 2075 or get a waterproof high torque servo. Other that the truck ran good changed gearing to 19/50. Outside temps is around 57*. So my motor was 95* and esc was 88*. Hmmmm kinda weird if you ask me I can't see dropping 3 truths would change the temps over 40* maybe it will. And thanks to elsob I'm now running 40k in front diff and 100k in rear diff and what a difference it has
  11. #331
    Jun 2014
    Kansas
    3,013
    Tore my truck apart to do maintenance and well some was harder then other areas. Rear outer bearing right side was gone
    So I fixed all the rear bearings even in the diff housing changed fluid put back together. KH mount bearing still running strong.
    Time for the front. And this is what I found pin broke for the out drive only one side
    And then I noticed the front wheels would get hung up when turning the wheels by hand so I found pinion bearings seized and opened the diff and what do you know I have broken spider gears
    Fixed them all up good as new for now lol. That would be the first for me to break inner gears and also the set pins for the axles.
  12. #332
    RC Qualifier Marioffroad's Avatar
    Oct 2014
    NB,Canada
    262
    Wow. That's some mild carnage there. I don't know if those pins are the best solution. They are free on one side,not binding anything...
  13. #333
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by Marioffroad View Post
    These are the pins I use and style of pins everyone else uses in place of those small set pins that comes with the axles. Honestly I don't know what I did for this to happen. Not unless it was last weekend when I tested out the 19/54 and changed a few things that was binding to get my temps down. I did hit a parking block you find in parking lots I broke an A arm on that side right at the bulkhead.
    I was able to run a pack through and everything is smooooooooth as butter. I also balanced my tires last night man was they out of wack.
  14. #334
    Wales in the UK
    6,462
    Wow bearing and spider gear meltdownbut glad you have sorted it out and back in the driving seat bro...peace
  15. #335
    7,264
    Wow!! How did you manage to break the spider gears? Aren't you running XO-1 diffs?
  16. #336
    Jun 2014
    Kansas
    3,013
    Yep I have xo1 both front and rears that's what's weird. The outdrive gears was still good well almost. There was some chiped teeth on one side. But not missing teeth
  17. #337
    Wales in the UK
    6,462
    Do you think you may have over tightened anything a bit too much...peace
  18. #338
    Jun 2014
    Kansas
    3,013
    Nope. After putting at together I always check to see if there's binding. When I rebuild it last night I even put an extra shim in on the other outdrive just to see what it feels like. It was tight. Kinda hard to explain. ( Ok have you ever pushed your pinion gear inside your diff inward more and moved the ring gear by wheel. You can feel a difference on how it grabs )
  19. #339
    7,264
    Did you put two teflon washers on each side of diff pinion output shaft? I know one side has one already. I did try putting on the other side but when put together it was tight and grinding.
  20. #340
    Jun 2014
    Kansas
    3,013
    Yea that's what I did just to see what it felt like. But I did this last night after finding all this and rebuilding it. I only had one washer in at time of destruction. I noticed same as what you said so I removed the one washer that isn't suppose to be there and put it back together.
    And it was one Teflon washer on each side if that's what you mean by two of them. Or two on each side then no. Just one on each side
  21. #341
    7,264
    opps I meant to say one on each side lol. I did put a thin washer on each pinion gears F/R center driveshaft.
  22. #342
    Jun 2014
    Kansas
    3,013
    Really. How's that working out on the pinion's
  23. #343
    7,264
    I don't know how I have super thin washers that happen to be the right size lol but I never like the amount of play with ring to pinion gears.
  24. #344
    Jun 2014
    Kansas
    3,013
    Did you take out all the play or some of it
  25. #345
    7,264
    There's still play but not as much as without washer.
  26. #346
    Jun 2014
    Kansas
    3,013
    That's cool. I guess if there was no play at all you'll have a chance of binding the driveline which wouldn't be good.
  27. #347
    RC Qualifier traxxasvxlbasher's Avatar
    May 2013
    Alicante, Spain
    780
    Nice build man! love how it's looking! wow, thats some carnage with the diffs.... what washers are you talking about? i dont have any washers/shims on my diff. i know its very sloppy but i have always thought it was supposed to do lol. i must have been lucky with the diffs (knock on wood)!
    | Slash 4x4 | Stampede 4x4 | E-Revo BL | RPM |
  28. #348
    Wales in the UK
    6,462
    Are you guy's using traxxas part number 1985 by any chance....peace
  29. #349
    May 2013
    Alicante, Spain
    780
    i dont use them lol, didnt even know they exist!
  30. #350
    7,264
    I don't think these are traxxas washers, I found them from my bro old rc tool box and he has Mugen truggy.
  31. #351
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by traxxasvxlbasher View Post
    It's the washer that comes with the diff kit. There's only one washer and 2 rubber seals. But the other type of washers we was talking about are for the pinion gears of front and rear diffs
  32. #352
    Jun 2014
    Kansas
    3,013
    Nope not those. Those are for the stub axles
  33. #353
    Feb 2013
    Montreal, Canada
    5,590
    Hey Er33, I see that you too have used the long grub screws for the x duty, I am thinking of not using the orginal screws (2 for each side); are those the erevo scews that you are using or any other if so what is the part number please.
    Thanks
    Live life to the fullest
  34. #354
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by Jezza View Post
    Thanks
    Yea those are part tra5145. But the tra5189 fits better they are 2mm shorter
  35. #355
    Jun 2014
    Kansas
    3,013
    proline is coming out with mounts for the pede adjustable at that.
    http://prolineracing.com/performance...-stampede-4x4/
  36. #356
    7,264
    that's good find, forget telluride body post, might change direction with mine now
  37. #357
    Dec 2014
    10
    Wicked truck!! Thats the color scheme I wanna do on the 50s body. What paint did you use?
  38. #358
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by benjammin5150 View Post
    Thanks bro.
    The hummer body is a candy blue with silver back with marble effect and black bottom and silver metallic between the two. The candy blue is hard to find pactra is the paint I use to get but no longer in business.
    The 72 c10 body is a green and blue both metallics both by tamiya color
  39. #359
    Jun 2014
    Kansas
    3,013
    Yea don't know when they'll be out though lol
  40. #360
    Dec 2014
    515
    Holy crap these things are huge compared to the gtrs
    Are these the castor shocks you said to use fronts all the way around spennie? On page 5?
