    Mar 2014
    212
    Shock bolts keep coming loose
    My upper shock bolts keep coming loose should I be putting loctite on them?
    Sep 2011
    Iowa City, Iowa, USA
    4,346
    Use a little bit of superglue. Or do what I did. I used 40mm screws and drilled the screw slightly larger. Then I used a bushing that is included in the parts tree then I used a lock nut.
    Aug 2013
    Brazoria, Texas
    1,638
    Lock tight will work as well...
    Spartan Jet Boat
    Alias
    Fiero GTP
    Michigan
    7,961
    ^^Jimdog thats the way to go IMO.
    Another thread from today.
    This will lead to bigger issues in the future, loctite is not for plastic.
    Sacramento Ca 95841
    104
    Proline makes a kit to fix this problem best thing you can do!
    Michigan
    7,961
    Quote Originally Posted by Rickster25 View Post
    My grandson runs that kit on his sc10, save your $10 and use you own screws and nuts.
