Thread: glue tires?
    Jan 2014
    Ohio
    809
    glue tires?
    Do I need to glue tires on my e maxx? Does it depend on the speed I run? Mine is an older e maxx and I run mostly in the grass. I will probably use 2s or 3s lipos. Thanks, Don
    Traxxas Marshal
    Mar 2003
    Wherever the road takes me.
    37,468
    If your tires are not glued, I would definitely recommend gluing them.
    RC Champion mrtwohands's Avatar
    Aug 2012
    Warner Robins, Georgia
    1,835
    If you're not into gluing tires maybe check out some beadlocks but yes you should always glue tires. They will just spin off even with lower speeds
    Jan 2014
    Ohio
    809
    Thanks; I have 4 new tires on order, unglued. Do I use super glue or is there something better? Any videos on how to glue?
    Thanks; Don
    Aug 2012
    1,835
    I would use CA glue. Its specifically made for gluing rc tires. Usually less than $5 a bottle. There are quit a few videos on YouTube about how to do it.
    http://m.youtube.com/watch?v=d0X_2GJI1Fw
    Traxxas Marshal
    Mar 2003
    37,468
    Quote Originally Posted by mrtwohands View Post
    The factory tires on the 3906s would stay on the rims if they weren't glued (I didn't glue mine for years); however, the rims will spin inside of the tires under load. Aftermarket tires will definitely come off, though.
    Quote Originally Posted by dontrinko View Post
    Super glue (CA glue) will work just fine; I've been using it for years without any issues. There are tire glues specifically designed for R/C use, but I'm not convinced that they work any better.
    Jun 2014
    San Gabriel, CA
    6,177
