Results 1 to 25 of 25
Thread: What to get
    Jul 2014
    What to get
    I am going to get a stampede vxl 2wd or slash vxl 2wd. I can't figure out which to get. I'm just gonna be bashing. What's better
    May 2010
    315
    I have both and I have a blast with my stampede. The smaller tires with less aggressive tread on the slash do not get near as much grip and it will get stuck easier, but the slash will handle a little better as its not a wheelie monster or as top heavy.
    2x 2wd Slash|Slash 4x4 PE|MM E-Revo|Grave Digger
    RC Qualifier Thefixxer73's Avatar
    Aug 2013
    I'm here
    655
    Get the Slash and make it a Slash MT (monster truck) but putting bigger tires and rims on it. Suggested combo would be 2.8 Trencher MT tires on any rim of your choice (most common is Desperado) using fronts on all 4 corners.
    Slash MT will give you the stability of the Slash with the off road ability of a Stampede. All the parts are interchangeable between the two trucks with the only significant difference being the chassis, steering set up, skids, and the tire/rim combo. Otherwise they are identical assemblies front and rear. You could get one or the other and buy the chassis for the other and swap them out to what you like best. Cost of the truck plus less than $10 for a chassis. I would suggest the Slash initially because of the different steering assembly. If you go with p2de you also need bellcranks to switch to the slash steering.
    This space reserved
    RC Qualifier Shadow_summit757's Avatar
    Feb 2014
    Newport News VA
    594
    I would get a Stampede VXL if you want to get an RC out of the box that's able to bash. The Slash MT is cool I'm working on one now but it cost more to build and time.
    Monster Energy & F-150 Raptor, Teton, Slash 4x4
    RC Champion No One's Avatar
    May 2005
    Minnesota
    1,196
    Depends where you are driving it. Slash is more durable, but can not handle grass.
    MT is the best of all worlds, but cost goes up.
    Out of the box, the Stampede is a better basher for grass and rougher terrain.
    The steering set up on the Stampede is its greatest weakness IMO.
    Slash 4x4
    Stampede - 4x4 x3
    Prerunner x3
    Teton
    Aug 2013
    I'm here
    655
    Quote Originally Posted by No One View Post
    Agreed. 2nd only to the castors and that affects both models. Don't know why Traxxas don't just include aluminum and charge just a tad more for the RTRs. That or engineer a stronger stock part. They gotta know its a severe weak point.
    This space reserved
    Feb 2014
    Newport News VA
    594
    Quote Originally Posted by Thefixxer73 View Post
    That's why theres RPM parts.
    740
    Quote Originally Posted by Shadow_summit757 View Post
    But the RPM parts allow more flex in a spot where rigidity is the key. It sucks trying to mess with bent king pins. Aluminum is the way to go no question
    Feb 2014
    Newport News VA
    594
    I would get this if you want Aluminum Parts http://www.integy.com/st_prod.html?p...w#.U8REyKVOV1s.
    Port Alice, BC, Canada
    1,450
    I would have to strongly disagree with the post above, junk IMO. If your going aluminum stick with TRX or STRC.
    R4lly GT8 | Backsl4sh | Sl4sh MT | Sl4sh | P4de
    Feb 2014
    Newport News VA
    594
    Most of my parts are TRX but that Integy kit has work for my friend well.
    Aug 2013
    I'm here
    655
    If you are lucky enough to get Integy parts that were milled right they will work fine. Integy, for a number of years got a bad rap for imperfections in milling, which they continue to do. Agree with strc and TRX. Hot Racing is also nice quality for aluminum parts.
    This space reserved
    Jan 2008
    South Jersey
    8,407
    Milling is only a small part of the problem with Integy parts. All the precision in the world doesn't make up for the garbage alloy they use.
    1,450
    How are they still in business? Also I have never understood why certain brands are banned from this site and quite frankly there parts and service is much better then this junk, ban integy IMO.
    Jan 2008
    South Jersey
    8,407
    Quote Originally Posted by Stephan81 View Post
    Not sure about all of them, but I do know that at least one company is banned because they sell cheap knock-off connectors under the Traxxas name.
    1,450
    That's quite ironic and that's all I'm going to say about that lol.
    20,550
    That's probably a much wiser choice than the one you made to bring it up in the first place.
    Alt-248 on the number pad =
    Jul 2014
    What do i need to make a slash MT
    1,450
    What to get
    2.8 wheels and tires, a body like a svt raptor(many other options as well), and different body mounts, I believe on the front I'm using a p4de front mount flipped around.
    This is for the sl4sh mind you. Same idea for the 2wd, body mounts are different though. I've never owned a sl2sh.
    Feb 2014
    Newport News VA
    594
    My slash MT has a Pro line Summit Apoc body.
    Aug 2013
    I'm here
    655
    What to get
    2.8 wheels and tires, a body like a svt raptor.
    That looks bad!
    This space reserved
    May 2005
    Minnesota
    1,196
    Quote Originally Posted by Mitkoj View Post
    Also change gearing.
    Slash 4x4
    Stampede - 4x4 x3
    Prerunner x3
    Teton
    May 2005
    Minnesota
    1,196
    Slash 4x4
    Stampede - 4x4 x3
    Prerunner x3
    Teton
    May 2005
    Minnesota
    1,196
    Slash 4x4
    Stampede - 4x4 x3
    Prerunner x3
    Teton
    Feb 2014
    Newport News VA
    594
    That was Awesome
