Results 1 to 14 of 14
    Jun 2014
    5
    installing a Castle Creations SCT Sidewinder Waterproof ESC & 3800kV Motor Combo W/5m
    I have a stampede xl-5 and im upgrading to a Castle Creations SCT Sidewinder Waterproof ESC & 3800kV Motor Combo W/5mm SC10 and i need some help installing the new motor or a link for a video that show how to do it ....please....thanks
    N. Idaho... Da Sticks!
    8,091
    It is pretty straightforward, what are you having problems with?
    - Pull the old motor and ESC out
    - Bolt the motor on to the motor plate
    - Install the pinion on to the motor shaft using really good tools to tighten the grum screw down, or use locktight, or both.
    - Set the gear mesh with just a hint of backlash (or use a piece of paper).
    - Both the ESC in (light have to use double sticky tape or a RPM motor mount.)
    - Connect up the three motor wires.
    - Connect the ESC to the RX (channel 2).
    - Ensure the wheels are off of the ground
    - Turn on the radio and zero all contols for the throttle, then turn on the ESC putting it into programming mode and calibrate the ESC (the manual will tell you how to do this).
    - test the steering.
    - Test the throttle (forward, back, and brakes)
    -Run the truck
    Let us know if you have any questions.
    Jun 2014
    5
    thanks very much guys!!!!
    Mojave Desert
    3,028
    Greatscott is right on...if you happen to get stuck, then here's a vid that can somewhat guide you on physically installing the motor.
    https://www.youtube.com/watch?v=8fwOv_46xH4
    Start vid at 2:17 to skip the commentary.
    740
    installing a Castle Creations SCT Sidewinder Waterproof ESC & 3800kV Motor Co...
    Wait, i thought there were 2 servo spots? I thought the ESC plugged into spot number 3?
    EDIT- the first two slots are labeled ch1. The third set if prongs is ch2.
    Jul 2013
    Vancouver B.C.
    569
    Quote Originally Posted by rcnewbie1234 View Post
    It is the third slot but because there is two channel 1s it is still channel 2 i have made this mistake before though. If your steering wheel operates your throttle you have the esc wire (channel 2) plugged into channel 1's second servo slot
    8,091
    Yeah, don't confuse channels with ports. Traxxas RXs have two servo ports (channel 1), these are used for the larger trucks (E-Maxx & Summit) that run two steering servos. For the smaller trucks, it is just a convienent place to plug in lights or a BEC.
    Sep 2016
    24
    Does it matter if I use 2s or 3s on this combo? Is there a good water proof system where I can use 3s lipos?
    Jul 2014
    NAWLINS
    3,952
    You will find running 3S is very uncontrollable. 2S is fine. If your wanting to run 3S it has been done by others where Castle states 3S is not recommended on this combo. I run the SV3 on both 2 and 3S with no problems. I have upgraded the ESC to the MMP which is better running higher than 2S.
    T/SportMax/Slayer Pro/Bandit
    Stampede/Rustler
    Sep 2016
    24
    Quote Originally Posted by JerrysMaxx View Post
    Could you send me a link to the esc?
    Jul 2014
    NAWLINS
    3,952
    Quote Originally Posted by rstrobel1621 View Post
    https://www.amazon.com/Castle-Creati.../dp/B003T6TG20
    I run this with my 4600kv and best of all you can run the new Castle sensored motors.
    Stampede/Rustler
    Sep 2016
    24
    What battery and gearing do you use? And what's the top speed?
    Sep 2016
    24
    Also could someone respond to my thread
    It's called "Brushless System for 2wd Stampede" its on this forum
    Here's the link:
    https://traxxas.com/forums/showthrea...r-2wd-Stampede
    Jul 2014
    NAWLINS
    3,952
    I run numerous combinations but my favorite bash setup is 23/86 on 2s. I don't care about top speed so I don't monitor iy but it is plenty fast enough to chase cars down the street and sometimes blow right by them
    Stampede/Rustler
