Page 1 of 2 12 LastLast
Results 1 to 40 of 49
    Ontario
    664
    Another e-revo build
    Mods can plz remove other thread
    So recently purchased a used e-revo brushless model with mamba monster and castle creations
    Truck runs flawless so far... And 2 lipos
    So when I got it didn't have a wing now it does
    Needs a few other missing parts no rx box as well
    Also came with the dx3e
    Anyways was wondering how do u guys get the sloppy axle carriers to not be sloppy
    Any help on what u guys use for uploading pics that be cool too
    Plz no judge my grammar or English skills cuz there not there at all
    Feb 2013
    Montreal, Canada
    5,590
    Where are the pics .........
    sound good, have fun with the truck, the e-revo is just awesome all round
    Put a picture of you axle carries, it can be tightened, you have to remove the cover with one of the tools first and then use a hex key to loosen or tighten to the arms
    Live life to the fullest
    Jul 2014
    148
    There's the screw inside that will bring it farther or closer to the a arm. There's a bigger cap that screws in on the pivot ball, that is most likely the play you are speaking of. If you look through the spokes of your rim and remove the cover you should be able to see.
    E - Revo Fixing it daily.
    Ontario
    664
    Ok I'll look into that thanks
    I would post pics if I knew how
    Jul 2014
    148
    I guess you need a photo bucket account.
    Ontario
    664
    Try this
    http://s1377.photobucket.com/user/jo...0188d.jpg.html
    That onyx 245 looks legit
    Feb 2013
    Montreal, Canada
    5,590
    Quote Originally Posted by traxxaspro View Post
    Nice set up, you can actually edit it and resize to 640 to be able to fit on here.
    20,070
    Quote Originally Posted by Jezza View Post
    The forum performs the resizing automatically.
    Are you using multi-adapters as battery connectors? Something looks very wrong there.
    Alt-248 on the number pad =
    RC Champion NFS's Avatar
    Aug 2013
    2,097
    Definitely something is not ok there...it is an accident about to happen..I saw more than four connectors also even different types...
    Feb 2013
    Montreal, Canada
    5,590
    Oh thanks for the info, I was under the impression that I had to resize them so people with dial up connection will not have problems seeing. Spares me the time of doing a double job.
    Yeah I just noticed those, they don't look right as mentioned, or the batteries set to run in series???
    Ontario
    664
    Yeah it's just a multi connection the battery's I got are deans
    Sorry not familer with photobucket yet will try to figure that out
    kansas
    8,677
    Grub Screw Knuckles
    Post 323
    http://traxxas.com/forums/showthread...=1#post5570206
    post 214
    Ontario
    664
    Thanks I'll have to try that out
    Ontario
    664
    Does the castle need to be on for the castle link to work ?
    Aug 2013
    2,097
    Nope, just unplug the esc from the receiver and plug it in to the USB adapter or field card.
    RC Qualifier traxxasvxlbasher's Avatar
    May 2013
    Alicante, Spain
    780
    Quote Originally Posted by NFS View Post
    it will have to be connected to the battery if you are using the programming card.
    Aug 2013
    2,097
    Quote Originally Posted by traxxasvxlbasher View Post
    Yeah..i meant if you using the field card as a usb.
    Ontario
    664
    Nope using the castle link no field card
    What are some good setting btw
    Jul 2014
    148
    3.5 low voltage cut off. I personally like the 10% engine brake.
    Ontario
    664
    Ok cool thxs
    Ontario
    664
    Going to possible order some spc battery's tomorrow 3s 5600mh 60c
    Currently on 2s
    Might order the onyx 245 soon too
    Ontario
    664
    On the way some spc 3s lipos can't wait to try that
    Need to fix the axles wobble still tho
    May 2010
    315
    I hope you read up on the e-revo and 6s. Get ready for blowing tires, snapping driveshafts and shredding diffs.
    2x 2wd Slash|Slash 4x4 PE|MM E-Revo|Grave Digger
    Jul 2014
    148
    Devil I run 6s. Proper slipper adjustments and responsible driving and no problems! Before i was snapping g shafts and breaking diff ring gear teeth. Since I've learned the two things i have been good for quite a few runs.
    Ontario
    664
    I'm only going to 3s not 6s I should be ok
    20,070
    How are you gonna manage that?
    Oct 2013
    431
    2 x 1.5S
    Apr 2014
    148
    Currently on 2s
    I have the Onyx 245. It is a good charger for the money, however it does not have a storage or discharge mode. Two features that are kind of important.
    Ontario
    664
    So 2x 3s means it's 6s setup the. Sorry new to electric
    20,070
    Some people have run a pair of 3S packs in parallel for double the [slow] runtime. It's not outside of the realm of possibility.
    Ontario
    664
    Now ur just confusing me
    Take a look at the pic is that parrallel setup ?
    20,070
    You want me to trace THAT spaghetti bowl???
    The ERBE comes stock set up for two battery packs wired in series. So yours is probably not parallel. But I could convert it to that in about 90 seconds.
    My point above is that 3S has been done before, not that you should do it. But for the future, with electric vehicles you typically add the cells of the packs you are using. I believe you mentioned 3S packs. So that would be 6S, as you noted.
  33. #33
    Ontario
    664
    Figures lol I should of known better looks like I'll start breaking stuff
  34. #34
    Ontario
    664
    Anyone using the thunder chargers they look pretty good was thinking of this one
    http://www.hobbypartz.com/75p-ac0620-ac-charger-ii.html
  35. #35
    20,070
    I'd get a Hyperion EOS 0730I NET3 charger (formerly $100, now $125 shipped) and a converted server power supply long before I bought anything from the battery cooker company known as Thunder.
  36. #36
    Jul 2012
    Eastern Iowa
    336
    Check out progressive r/c or buddy r/c for chargers both good company's easy to work with.
    IMO buddy r/c has the best customer service ever, will answer any question about the stuff they sell and won't treat anyone like a ldiot I ordered some stuff on a saturday had it Monday night.
    Buddy's V3 parallel charge boards are great for charging multiple batteries at the same time.
    Erbe, Merv Vxl, Rusty Vxl.
  37. #37
    Ontario
    664
    Ok thanks
    Quote Originally Posted by JJ1224 View Post
    I caved went with pro rc got the 206b and 350p combo in the mail
    Same setup as mz a few threads down
  38. #38
    20,070
    Nominally less powerful and about the same price as my suggestion, but still a good choice. You won't be growing out of that combo for a while.
  39. #39
    Ontario
    664
    That one u posted does look pretty good...
    But seems to be out of stock
    Anyways what settings could my new battery's be charged at
    5600mh 50c 3s lipos
    Also my 2s 5000mh 30c one
    Please watch the language.
    -ksb51rl
  40. #40
    kansas
    8,677
    general rule is one amp per every 1000 mAh
    so
    5000 mAh 5 amps
    5600 mAh 5.6 amps
    8000 mAh 8 amps
    unless you are charging two batteries in parallel, then double the amps
