    Aug 2014
    4
    ERBE Jumping/suspension/ride height question
    Hi! New here and only 15 so don't get TOO mad :P
    Okay so I've been running my new ERBE and doing many jumps and realised the skid plates hit the ground very often. How do I make the erevo run like my old Revo 3.3 used to and jump super high and it would just absorb the shock completely without the skid plates hitting the ground? I've already changed the suspension arms from the middle hole to the inner hole on the mount in the wheels, but what else can I do without buying anything to augment the ride height or, not let the skid plates hit the ground after jumps? Can I tighten the springs a little?
    Thanks, Nic
    Oct 2013
    431
    You're 15 and you use the word augment? And punctuation? Your English teacher would be so proud!
    What springs have you got installed?
    And how much preload have to already got?
    Are you using the P2 or LT rockers?
    What weight shock oil are you using?
    Aug 2014
    4
    Everything is stock, so red springs with gold little marks on them, if preload is the amount of time that I tightened the springs well, I tightened them a little to make the suspension stiffer, I did not install the long travel rocker set so I guess the p2, and once again stock shock oil so I don't know what that is.
    Thanks for the compliment and the reply
    kansas
    8,677
    do not install the LT rockers unless you have the Summit CVD drive shaft, you will break a lot of stock CV drive shafts.
    The ERevo is a bit faster than your 3.3 so it is going to bottom out on big air, and if it doesn't you will have the suspension so tight it will bounce like a basketball, and start breaking suspension parts.
    Ride Height & Suspension Set~Up:
    My Bash set up:
    P2 Rockers 80 wt Shock Fluid, Blue Rear Silver Front, inner hole, and Traxxas sway bars.
    I set the shock preload by pushing the chassis to the ground.
    If the springs fully compress, back off the preload, if not fully compress increase the preload..
    Will also give you a little more ride height..
    Aug 2014
    4
    Thanks for the info...
    Jul 2012
    Eastern Iowa
    336
    My setup is pretty much the same as 87s but I use 60wt shock fluid and the variable damping kit.
    So your probably going the have to shed some coin to improve over stock to the point your looking for.
    Erbe, Merv Vxl, Rusty Vxl.
    Aug 2014
    4
    Okay! Thanks...
