Results 1 to 16 of 16
    May 2009
    209
    Summit only 1 side of the rear wheel turns
    Hello,
    Lately, I noticed only one side of the rear wheel turns. All three wheels turns , except the right side of the rear wheel. I am not sure what is the problem.
    Any ideas what maybe the causing this.
    thank you in advance
    Tomasito
    Jul 2013
    Connecticut
    838
    I think your rear diff is toast. Likely you stripped the gears inside the diff. You can buy a rebuild kit.
    Sep 2012
    173
    Can you spin that wheel by hand?
    Aug 2014
    346
    I think Spencer is right man just get some lem diffs u should be OK then
    Sep 2012
    173
    Its possible that the bearings on that wheel have siezed up causing the power to go to the opposite wheel. Thats why im asking if it can be spun by hand
    May 2009
    209
    Yes, I can spin that wheel. Yeah I think the gears inside are stripped
    where can I buy a rebuild kit?
    Tomasito
    Sep 2012
    173
    Your local hobby store should have everything you need or check ebay.
    But as Billgates1234 mentioned you would be better off upgrading to LEM (leading edge machining) aluminum diff cups and hardened spider gears.
    Ive been running them for almost a year now with Mamba Monster/2200kv on 6s and they are holding up great! And I havent heard of anyone being able to break them yet.
    RC Qualifier Rich2's Avatar
    Feb 2014
    Western New York
    536
    Quote Originally Posted by tomasito View Post
    Does it also spin the drive shaft, if it doesn't then it
    could be a pin in your hex hub.
    May 2009
    209
    yes, the drive shaft also spins
    Tomasito
    May 2009
    209
    Quote Originally Posted by ttypedan View Post
    hello ttypedan,
    I checked on ebay , I can not find LEM, aluminum diff cups.
    I appreciate it if someone can post a link where I can purchase the LEM differentials (aluminum)
    thank you
    Tomasito
    Sep 2012
    173
    Ill see what I can do. They may be out of stock at the moment
    Sep 2012
    173
    Try again. Search for "lem summit"
    They have a few on there but not the sets with the hardened spider gears.
    Email them and ask if they will have any available soon.
    Also it would be a good idea if you disassembe yours to see exactly what is broke incase its one of the outdrives. You may need to pick up a few parts from traxxas even if you go with the LEM stuff
    Sep 2013
    Maysville,Ky. USA
    789
    2,088
    gears might be ok, have you ever shimmed the diffs? if not they might just need that, is there any odd clicking noises when any wheels turn?
    2,088
    possibly cheaper and stronger would be the LST2 diff swap.....then you could put some 8s too the wheels......
    Dec 2008
    323
    Might be a long short, But i have a simlar problem,
    when all 4 wheels are off the ground the front 2 and left rear all spin freely, The right does not, usless use the diff lock,
    I have looked at this and what seem to be happening is the drive shaft is rubbing on the top of the A arm, If i push that side up slightly (as would sit on the ground) seem to run fine,
    Fix, you could need to change diff oil, or dont run when off the ground,
