Results 1 to 17 of 17
    Oct 2014
    30
    Throttle sticks in reverse
    I just picked up another rustler with a brand new radient reaktor brushless system I'm having two issues with it.
    When I turn on, I wait for it to go through the cycles like the manual says. The steering works, but I have to mess with setting button for the throttle to work. After that, I never have an issue with it.
    Lastly, the throttle sticks in reverse. If I hit the trigger again, it stops moving, but if I tap it once if I just want to move it a little, it goes full throttle in reverse.
    Are these both settings I need to adjust, or something I just have to deal with?
    Thanks!
    This post has been edited to removed filtered language. If you type something the filter turns into asterisks you must edit your post to remove the offending language.
    Dadx2mj
    Rotterdam, Netherlands
    8,617
    Did you follow the throttle calibrate procedure?
    15,208
    Adjust the neutral setting on the throttle channel. Adjust it forward a bit, and it will stay there when you release the trigger...
    Ya can't polish fertilizer...
    Oct 2014
    30
    I did. I tried it a few times to make sure I didn't mess anything up. Neither one came with instructions so I'm relying on information online. I found a manual online for the radient, although it isn't that informative. I can't find anything online for the radio though.
    Oct 2014
    30
    I will try that when I get home. Thanks
    Oct 2014
    30
    A new development when I was messing with the throttle settings. I ran out of time at lunch to play with it so I turned the remote off and the truck went into reverse and stuck like it has been doing. I was messing with the throttle trim and all it did was cut off reverse. Once I started moving I back, it started spinning again..
    Oct 2014
    30
    Hopefully none of you get too irritated with me, I'm still a noob. Which setting is that? These are the difference setting I have...
    Thanks again everyone for all the help!
    8,617
    Press the buttons TH.TRIM so that you see the lowest arrow on your first picture move.
    Oct 2014
    30
    I did that. When the truck is stuck in reverse and move it to the left so it's around -22 or so. It stops but then I have no reverse. I go to move it back a little more back to center and the tires start to spin again.
    Jul 2014
    710
    I had a car that did that and I had to reset the esc back to factory settings and recalibrate and rebind the controller.
    Oct 2014
    30
    I've done the reset on the controller but that hasn't helped. Is there another reset on the esc?
    Jan 2014
    South NJ
    296
    what type of radio is that
    Kyosho Inferno VE, Anza Slash, Rustler VXL
    Oct 2014
    30
    ******* 3xs
    Oct 2014
    30
    Can a mod please remove the asterisk? I can edit the post. Thank you!
    Oct 2014
    30
    Just an update. I took everything to hobbytown for help and they got me squared away. I wasn't calibrating it correctly.
    Jul 2012
    37
    sounded like you were getting you neutral and reverse mixed up when you were calibrating it. Did they show you what you were doing wrong?
    Oct 2014
    30
    When setting up the esc, i wasn't doing the right sequence of button pressing. Having it calibrated now seems to have fixed all the issues I was having previously. 😀
