Results 1 to 18 of 18
Thread: Rustler 100Mph
    Nov 2014
    Utah
    23
    Rustler 100Mph
    I am doing a build of a rustler that goes 100mph. Im wondering if the XO-1 Motor will fit in the rustler or if i will have to settle for the mxl-6s and 2200kv system?
    Dec 2013
    WI
    745
    Settle? Lol.
    The Mamba Monster with a 1515 motor is more than capable of doing 120mph on a Rustler.
    Bashin' n' crashin'
    Nov 2014
    Utah
    23
    I Understand this which is why i dont mind that. Im just wondering if the xo-1 motor will fit thanks
    Aug 2007
    So Cal
    21,511
    Pretty sure the mounting holes will line up but both the XO-1 and the Castle 220kv motor pretty much require use of an aluminum aftermarket tranny case with an open motor bay to fit,,,,or a lot of Dremel work on the stock case.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Nov 2014
    Utah
    23
    Alright Thanks.
    RC Qualifier RadReptiles831's Avatar
    Nor Cal
    869
    Where are the pics bro? I love speed rustlers. Good luck on your build!
    Nov 2014
    Utah
    23
    Do You Think An Integy aluminum case would work? Im not a big fan of integy but I happen to have that case laying around on my work bench.
    Nor Cal
    869
    HR makes a good tranny case. They make a full aluminum and an composite case and aluminum motor plate. I have the 2nd of the two on my 2wd rally and it's a great tranny case. Plus it's only $28 shipped on ebay.
    South of St Louis
    6,369
    I dont think my HR case has a flat motor plate, but it's been a while since I looked. The FLM used to have a flat motor plate but I don't know about the newer model. Most people like the Integy trans case but I dont own one. I'd suggest going for 60mph first, then 70mph etc... You'll learn a lot just by getting to 70.
    Nor Cal
    869
    It's flat and open.
    Jul 2014
    710
    Quote Originally Posted by WyattBoriFT View Post
    there are two style of integy cases one has the motor cover and one is more of a flatter motor mount. the flatter mount style is less expensive but will not work with the traxxas motor guard or wheelie bar and if you want a wheelie bar you will need an after market one.,,,,, mine looks like it would plenty of room for a larger motor, should I want one.
    Mojave Desert
    3,014
    Like i tell all the 100mph Rustler questers...keep us informed on your travels. Good luck cuz it will be needed.
    I was wondering though, 100mph in Utah? during the winter?
    Nov 2014
    Utah
    23
    Yes That Is My Problem, But i just started the build and i need to save up the money i get to get all the parts i need because im building it from scratch. Im doing this because i had a full transmission, a servo and a chassis just layin around and I didnt wanna go spend $230-$370 Dollars buying a new rustler when i had all those parts. So anyway im not worried about winter because Im estimating by the time i have this done winter will be coming to an end.
    South of St Louis
    6,369
    Thanks for the pic Rad, I was thinking of my golden horizons transmission case.
    Nor Cal
    869
    Any time O.G.!
    Jun 2013
    66
    wont work with stock trans.. most say a 1/8th wont, but theres proof it does, with zero issues.. but its 43mm, and the xo-1 is 49mm
    Jun 2013
    66
    and at 43mm it barely works mid motor if you choose that route..
    Apr 2013
    40
    An Integy aluminum gearbox will fit the castle 1515 2200kv motor fine if you use the right size gearing. When screwed in, the motor cannot slide foward or backwards, so you will have to play around with the size of the gears. The castle 1717 motor will not fit in aluminum gearboxes, but you might be able to grind down some of the gearbox. I have talked to traxxas and castle, and they said that pairing the 1515 2200kv motor and the mamba monster 2, would be faster than the mamba monster 2 with the xo-1 motor, so go with the 1515 2200kv motor and 6s. The xo-1 motor is 1650 kv and compared to the 1515 2200kv motor, the 2200kv will produce higher rpms instead of more torque, and a car the size and weight of the rustler, any 1/8 motor is overkill and so you will want to have more rpms. I could be wrong, but this is what traxxas and castle have told me when i built my speed rustler.
    this costs too much money
