Results 1 to 12 of 12
Thread: Diff Shimming
    RC Champion PowerToTheMaxx's Avatar
    Sep 2010
    Chicago, IL
    2,338
    Diff Shimming
    So, how does one shim a diff and where does one get the shims and what size.
    I have stock revo-spec diffs and I want to shim them. Do you shim the diff assembly side to side? Just the pinion gear?
    Part numbers and pictures would be very helpful, Ive been researching this for a while and have not come up with very conclusive answers as of yet.
    Thanks,
    PTTM
    This parrot is NO MORE!!! This is an ex-parrot!!!
    RC Champion NFS's Avatar
    Aug 2013
    2,097
    Sep 2010
    Chicago, IL
    2,338
    Thanks. Very helpful.
    Jul 2008
    51
    Can you give us the part numbers for the shims and where to purchase them?
    RC Qualifier ausprime's Avatar
    Cairns, Australia
    776
    I got my shims from AMain hobbies
    http://www.amain.com/search?s=shim&o=5
    My RC Cycle:
    Build it, Drive it, Brake it.
    Sep 2010
    Chicago, IL
    2,338
    Aug 2013
    2,097
    The brand won't matter just make sure they are the right size 6mm, 8mm
    Jul 2014
    NY
    685
    Just to add my 2 cents.... I would get more than one thickness of each size (6 & 8mm ID). Also, i was in your shoes a couple months ago with shimming the stock diffs. I am now doing the 1/8 diff/flm hybrid bulk conversion. Yes shimming the stock diffs helps. But they are still going to blow out.on you. If you are going to stay with the stock diffs an alum diff case and/or diff cup will also contribute to durability of the diffs. i shimmed my stock diffs but still only got maybe 15 runs out of it before blowing one up. One of the pinion bearings disinegrated so that may have been the reason but still.... And given, i was also doing alot of jumping. Idk if that contributed to blowing one out but shimming alone wont completely solve the problem of stripping gears.i just decided that instead of buying new gears and rebuild kits over and over that i would do the 1/8 conversion and hopefully get much longer use out of them.
    Sep 2010
    Chicago, IL
    2,338
    I know. Ive been strongly encouraged to get the FLM conversions, but I really dont want to spend the money right now. I just got nice bearings for the stockers and a new plastic case ($4 beats $30).
    My stock diffs have lasted me almost 4 years and would still be fine now if it wasnt for the bad bearings. If I was moving up to 5s or 6s and wanted to really hammer my truck, id get them but because Im sticking at 4s for a while and I run with pretty conservative MM2 settings Im going to stick with the stock setup. Also want to really test out my RPM bulks. Ive got nearly $1500 in RC hobby this year so im pretty much at budget anyway.
    Cairns, Australia
    776
    Quote Originally Posted by NFS View Post
    NFS, you can't get a better reply to this thread then the above. Very nice!
    My FLM Combo bulks are still going strong.
    For stock diff gears, with the alloy cup.
    My RC Cycle:
    211
    What bearings are you using? Boca, Acer, Avid?
    Cairns, Australia
    776
    I use BOCA and Avid.
    My most recent purchase was the Avid Revolution bearings. Metal on one side, and rubber on the other.
    My RC Cycle:
