Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 376
  1. #161
    7,264
    Quote Originally Posted by Marioffroad View Post
    It's coming together….
    I see you got 6.5mm castle bullet connector, how do you like it? I ask cause I have them too not long ago, they are huge
    now I'm about to try EC5 connectors for my P4de
  2. #162
    RC Qualifier Marioffroad's Avatar
    Oct 2014
    NB,Canada
    262
    I like the way they fit,very good connection it seems. I don't like that you can connect them reversed, have to pay attention. What chassis are you using again?
  3. #163
    Oct 2014
    NB,Canada
    262
    Ok so I finally got it where I want it I could probably gear it up more since my temps are REALLY LOW. So earlier today I ran it still had good temps but not where I want them. After my run I noticed my Mips was rubbing my arms right there by the carriers at that cross piece ( had to much droop) so I changed the ride height readjusted the center shaft to have a little play lubed up the moving parts on the Mips, put the sw8 esc back on (had mm2 in). Put a fully charged pack in and motor is sitting at 95f esc is 71f. Nonstop throttle only let off when in a turn
    Oh I'm also geared 19/54. That's why I said I could gear it up more. I need to get me a 52 spur
    I may have to start with the same gearing. I' going to try to fit the 21t pinion with the 54t spur, but it's going to be tight. I have a smaller spur,but I would have to get the revo slipper setup.
  4. #164
    Jun 2014
    Kansas
    3,013
    21 is the biggest you can go with a 54
  5. #165
    7,264
    Yeah I like it too and like you said it can easily be plug in the wrong way, so always pay attention lol. I'm using the same chassis for p4de/telluride.
  6. #166
    Oct 2014
    NB,Canada
    262
    Rise of the GreenReaper
    Woo-Hoo !!! Let the madness begin !!
    Thanks to all who shared their knowledge !!! Now for the tweaking !!
    Mario
  7. #167
    7,264
    truck look sick man did you airbrush the body yourself?
  8. #168
    Oct 2014
    NB,Canada
    262
    No.. I can't draw a stick man…LOL I painted it black and applied a decal kit:
    http://www.ebay.com/itm/Proline-Ford...item19f7845a40
    Thanks !!
  9. #169
    Jun 2014
    Kansas
    3,013
    YAAAAY !! A finish truck. You gonna strap that troll down for a ride. Seeing that last pic reminds me of a thread in the summit section where a guy used GI Joes for his build every pic the joes had a part and either taking it off and putting a new one back on. It was humorous and different lol
  10. #170
    Oct 2014
    NB,Canada
    262
    LOL.
    I did a run today.It was on snow doing a lot of spinning(very low traction surface) After 20-30 minutes,I checked the temps.The motor was at 142F.The ESC maybe 90F and fan on.The fan shut off after 5 min no action. The weather outside was -2C.The motor temp seems a little high for the conditions. I am geared spur 54T and pinion 21T.What do you think ? I am running 100K in front diff and 60K in back.I removed 1 o-ring from the tekno big bone giving about the same play as the stock.
    Mario
  11. #171
    Wales in the UK
    6,462
    Go down a few teeth on the pinion and see what temps you get then.but it may just be because the motor was hitting very high rpms that it went that hot....peace
  12. #172
    Oct 2014
    NB,Canada
    262
    Thanks Spenn.That's what I was thinking,high rpms,no traction to limit.The tires were ballooning the whole run,with the blue foam in them.I have a 19T pinion that I will try.Don't have to worry about backflips this time of year.
    Also,in my part ordering frenzy,I mistakingly ordered 3.8 wheels.I was thinking of getting 3.8 sling shot tires.What do you think ?
  13. #173
    Wales in the UK
    6,462
    3.8"Way to big and too much stress on the drive train see if you can swap or get your dough back man but with the 19t or lower your temps will be sick....peace
  14. #174
    Oct 2014
    NB,Canada
    262
    I was afraid you'd say that ! Bag is opened already.I'll try and find low profile tires for those rims LOL !! Gonna order a few more pinions..
  15. #175
    Jun 2014
    Kansas
    3,013
    Was you running with that jconcepts outer shroud
  16. #176
    Oct 2014
    NB,Canada
    262
    Yes,I was.Have to.Too much snow gets in on the guts.
  17. #177
    Jun 2014
    Kansas
    3,013
    That could be another reason to your heat issue. Not allowing air to flow inside and cool the motor. That's why I like my toys shroud its breathable and water repellant. Wish I had SNOW to play in so I can see if it actually keeps it out. I know when I run through water my chassis is dry. There is a mod I don't remember who did it but you can add a fan to that shroud.
  18. #178
    Oct 2014
    NB,Canada
    262
    Everything is going to be hit and miss until the spring I guess.Could put the motor fan I suppose.
  19. #179
    Oct 2014
    NB,Canada
    262
    Merry Xmas everybody !!
    Uploading a short video now ...
  20. #180
    Oct 2014
    NB,Canada
    262
  21. #181
    Nov 2014
    Ludington, MI
    116
    Great vid
    I had a blast watching my boys yesterday, had a couple cringe moments but overall was awesome, watching my wifes face when they launched across the yard was hilarious and the boys faces were priceless
    May have to get myself a vehicle next year lol
  22. #182
    Oct 2014
    NB,Canada
    262
    Quote Originally Posted by Yathump View Post
    Great vid
    I had a blast watching my boys yesterday, had a couple cringe moments but overall was awesome, watching my wifes face when they launched a tossed the yard was hilarious and the boys faces were priceless
    Get one now!!!!!!! Lol
  23. #183
    Nov 2014
    Ludington, MI
    116
    Lol not sure my wife would allow that considering I just bought two for Christmas
  24. #184
    Oct 2014
    NB,Canada
    262
    I hear ya!!
  25. #185
    Oct 2014
    NB,Canada
    262
    Chain time.!!
  26. #186
    Oct 2014
    NB,Canada
    262
    Some family fun !!! The first part is the same as before.I mistakenly tied it on with the new vids.
  27. #187
    Nov 2014
    Ludington, MI
    116
    Great video again
    I definitely need to pick up a couple more batteries for some longer runs, the good news for me is my wife took the boys trucks for a run and thinks she may want one now lol
    So I may have to buy two more next year
  28. #188
    Wales in the UK
    6,462
    Awesome videos dude you can't beat a bit of family rc bondingmy boy just turned 3 last week so this year I will train him up on the micro sct brushless and then next Christmas its on dude...peace
  29. #189
    Oct 2014
    NB,Canada
    262
    Great video again
    Ha Ha Ha !!! You Got it made now !!! LOL
  30. #190
    Oct 2014
    NB,Canada
    262
    Start saving now !! LOL
  31. #191
    Oct 2014
    NB,Canada
    262
    High grade aluminum ????
  32. #192
    Wales in the UK
    6,462
    Will do boss my girls are into computers so at least my boy will be with me...peace
  33. #193
    Jun 2014
    Kansas
    3,013
    Ouch that sucks dude.
    Nice videos that looks fun.
  34. #194
    Oct 2014
    NB,Canada
    262
    Yeah and wasn't even a hard hit. Thankfully I ordered Traxxas ones when I replaced the rear axle carriers so it's already repaired. I ran the machine today with no over tray and we had a lot more pavement. My motor temperature was about 40.!!!
  35. #195
    Jun 2014
    Kansas
    3,013
    That's huge difference glad your back up and running
  36. #196
    RC Qualifier traxxasvxlbasher's Avatar
    May 2013
    Alicante, Spain
    780
    Nice! nothing like having family fun with RC's! i remember when i was in denmark last year for christmas and it was all covered in 25" snow lol.
    | Slash 4x4 | Stampede 4x4 | E-Revo BL | RPM |
  37. #197
    Oct 2014
    NB,Canada
    262
    Quote Originally Posted by traxxasvxlbasher View Post
    Thanks. We got a lot early this year.
  38. #198
    May 2013
    Alicante, Spain
    780
    Great! wish i had some snow in Spain too! i was in denmark last year with my family tho and there was some snow i could try out!
  39. #199
    Wales in the UK
    6,462
    Get the rpm replacement there dude much better than anything else out there at moment by what I have read on a few forums....peace
  40. #200
    Oct 2014
    NB,Canada
    262
    Hey Spenn,better than the Traxxas aluminum??
