Simple question, how do you remove the body?![]()
there are 2 screws in the back you have to take out. i have heard of a quick release pod that somebody makes but i cant find it anywhere.
rlchobbies.com They have wheelie bars and the easy body removal deal
There are 2 screws in the back you have to take out. i have heard of a quick release pod that somebody makes but i cant find it anywhere.
gonna make that an upgrade for next year for sure
after thinking about it for a while.
I wanted to make a comment on removing the removing the body from your funny car....
to remove the stock body on a stock funny car ....what worked best for me is ........without undoing the front latch.....
leave the body on and latched then ,,,while I am sitting in a chair,,,
I lay the funny car on my shins with the nose on my feet pointing down,,,,
and so I am looking at the rear of the funny car,,,,, look slightly from underneath till you can see the hinge screws ....get your Allen wrench and loosen one screw side till you can turn it with your fingers ,,,,
then loosen the other side screw till you can turn it with your fingers and remove it .
then go back and remove the 1st side screw.. then un latch the front and ...done,,.......
for in stalling the body ,,,,lay the car on the chassis and latch the front latch ,,,,,
lay the car on your shins with the nose on your feet and look at the car from the rear locate the rear body hinge and by hand start one side screw then the other then tighten both with the Allen wrench ..
I agree with you!
2 screws at the back of the car is fine with me!
