    Jan 2015
    Michigan
    15
    Slash 4x4 Tires?
    Simple question: Would Slash 4x4 standard tires fit a Rally, or would I have to cut the fenders a lot?
    RC Racer mdschmidt90's Avatar
    Dec 2014
    Fruit Heights, UT
    248
    I had the same question, I was running my car at my local track today using proline bow ties on split six wheels and I know they are slightly larger than stock rally and they have to be close to stock slash tires... when I got home first thing I did was trim my fenders... my wheels rubbed a lot, I hated doing it but I hope it solved the problem cause the noise drives me nuts! This was even with my body post raised one notch. Sorry its not a direct answer but to give you an idea any wheel larger than stock I think will rub without trimming
    Oct 2010
    3,144
    Stock Traxxas Rally tire: Diameter: 4.26" (108mm), Width: 1.7" (43mm).
    Stock Traxxas SCT tire: Diameter: 4.33" (110mm), Width: 1.77" (45mm) - Kuhmo style
    The SCT tire is one millimeter more in radius and two millimeters more in width. That's not very much.
    Obstacle Magnet
    Dec 2014
    Fruit Heights, UT
    248
    After trimming my fenders, its 100% better. No rubbing and just slap a piece of duct tape underneath the wheel well and she was a quite smooth ride with the larger tires. Easiest thing to do is try them out and if you need to trim you will know! :-)
