Results 1 to 11 of 11
    RC Qualifier timmey77's Avatar
    Nov 2014
    Vienna, austria
    476
    12mm hexes wit 6mm bore
    Do you know if there are any 12mm hex wheel adapters available which have a 6! mm bore and are not from tekno?
    RC Champion skmfkr's Avatar
    Mar 2014
    Savannah, GA
    1,502
    just drill the hole 6mm
    37
    http://www.tmrcracing.com/12mm-HEX-ADAPTERS-F300.htm
    i believe these will work but i would contact them to verify. They say they are for the funny car which uses a 6mm bore
    Nov 2014
    Vienna, austria
    476
    I already tried this but the hole is now not exactly in the middle so it wobbles a lot
    Nov 2014
    Vienna, austria
    476
    thanks skmfkr they fit
    Mar 2014
    Savannah, GA
    1,502
    all you are doing is making tbe 5mm to 6mm. so it should still be centered. i got 17mm adapters now and dont have to deal with it anymore
    Nov 2014
    Vienna, austria
    476
    does anybody knows if there are also thicker hexes available? (7mm...)
    Mar 2014
    Savannah, GA
    1,502
    ive never heard of any more than 6mm
    Nov 2014
    Vienna, austria
    476
    not the inner bore
    i mean the width of the hex
    Mar 2014
    Savannah, GA
    1,502
    14mm 17mm 23mm are the only one i know of
    Dec 2014
    Fevik - Norway
    99
    I think the std Axial ones are 6mm wide...
    http://www.axialracing.com/products/ax30429
    Fastrax FTAX14 is 3mm wider than a std Axial hex
    Fastrax FTAX22 is 5mm wider than std Axial hex
    Axial rigs use comon 12mm wheel hex, but they have a bit of it poking throu the wheel, cut off that lip or drill the wheels with 6mm drill bit.
    Rustler XL-5 4600kv Castle 1406 3s
