Results 1 to 8 of 8
    16
    New owner tamed down parking lot bashing gears
    Hello everyone this is my first xo1. It hits 50mph locked and 50 mph unlocked. I know it has a 14 t pinion installed right now. Not sure on the spur. What ever stock was. In the bag I have 14 pinion
    34 pinion
    54 tooth spur
    50 tooth spur
    What is the fastest gear combination I can use. I want to be able to bash and drift and drive around and do a top speed run every so often. How fast do you think the chosen gears could go?
    What's a good combo for 80-85 but bashing through a entire pack just drifting and drag racing.
    Traxxas Employee TireSlinger's Avatar
    Sep 2010
    953
    The factory spur is 46. I like to run a 24T pinion. It's exactly half way between stock and top speed, mine hits around 75 geared that way. Great for most large areas you're likely to find. An area to run 100+ is an awesome find but not typically something easy to locate.
    If you're wanting to do drifting and general driving with the occasional high speed run I would run 46 spur and then try out pinions in the 20-25 range. If you do too much drifting with the 34t pinion you'll see high temps pretty quick.
    16
    Do you still run the factory spur gear (46t).?
    Chicago, IL
    332
    I run 46/29 with zero issues.
    16
    Quote Originally Posted by XO-1 MD View Post
    What kind of speeds do you see flat out? 80ish?
    Chicago, IL
    332
    85 is the fastest I've hit but that was not full throttle... space limited... but better control that the 34 pinion...
    Feb 2015
    29
    I use 1/1 but 52/46 would be possible
    Traxxas xo-1
    Stampede
    Eastern Shore, Maryland
    4,131
    With stock gears and unlocked, I can hit 56 pretty regularly.
