Results 1 to 16 of 16
    135
    side throw header
    hello all,
    does anyone know of a side throw header for the revo with the 3.3? i have a pipe i'd like to try and need a suggestion. i'd like to keep the ez-start if possible.
    thanks!
    justin
    SD California
    1,157
    You can't keep the ez start with a side pipe, also there isn't much point in doing it with a 3.3, although you can if you really want.
    14,279
    If I recall a long time ago some used a T-Maxx header flipped over. Initially I was going to say Jato header but since it along with other nitros have the exhaust port facing the side rather than the rear it doesn't make sense. Or they made a custom 90 bend in addition to it.
    Mar 2009
    1,981
    here you go
    http://www3.towerhobbies.com/cgi-bin...?&I=LXFAZ9&P=7
    along with the dual chamber traxxas jato pipe
    back in the day, my setup
    http://s42.photobucket.com/profile.php?do=editpassword/kgom...l?sort=3&o=314
    makes the 3.3 runs awesome and gets better run time... also your rear shock ends last longer and your rear shocks don't sag as much after a day of running.. (i suspect was cause by heat...
    you know.. i never had a sig.. but i do now...
    May 2007
    West Coast, Fl
    2,133
    That's the same set up I used as well back then.
    2009 Florida State Monster Truck Champion
    RBMods
    Mar 2009
    1,981
    ahhhh the good ole days..
    looks like we had the same radio as well..
    May 2007
    West Coast, Fl
    2,133
    What's up k, those were the good ole days!! lol I miss em.
    RBMods
    SD California
    1,157
    How about some pictures with bodies?
    Mar 2009
    1,981
    doing good PNT.. just enjoying to great white north, 96motorhead if you search the picture thread you will find lots of mine.. and PNT's
    SD California
    1,157
    Quote Originally Posted by kgombe1 View Post
    Found one on google:
    Mar 2009
    1,981
    man i have a whole bunch i will have to sift through.. but yes that one with the setup i posted
    May 2007
    West Coast, Fl
    2,133
    Body on with side pipe.
    RBMods
    14,279
    here you go
    I got the Jato part right and I knew the right folks from yesteryear would show up! I may consider this route if I do end up building a Slayer so that the pipe is hidden. Or I may go electric...
    135
    wow, thanks for all of the help. ive seen the hpi header, but was wondering if it works with the ez-start? i think i have an old t-maxx header, ill give it a go.
    i have an old dynamite pipe (probable 1/8th, but not sure) that i used to run on my jato, it was way to fast, easy to tune and kept temps down. now id like to put it on my revo, hoping to get the additional performance out of it.
    thanks,
    justin
    Feb 2013
    Parker, CO
    1,390
    Does that hpi header fit the TM? It looks like it would but not sure. Thanks!
    I have an RC problem...
    Mar 2009
    1,981
    Yes it does... It will fit any small block
