Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
  1. #41
    Dec 2018
    Kansas City, MO
    I have 4 LaTrax vehicles (maybe 5 if Hobbytown still has a sale). When a servo goes out on mine I replace them with Savox SH-0257MG Super Speed Metal Gear Micro Digital Servo.
  2. #42
    Jan 2019
    21
    Ecopower 640t direct replacement supposedly. What I did for now is made a bracket and mounted my 2075x for my shifting after I burned 2 2065's
  3. #43
    Nov 2018
    401
    I personally got the emax eso8aii servo with metal gears off ebay for $4. It is super fast, has bad torque and is relatively waterproof. You do need to modify the servo mount a tiny bit, but just shaving off a little excess plastic. I highly suggest staying away from the savox servo, unless you want to pay way too much for a bigger hassle. about the emax servo though I use my brushless sst for racing and that servo works great. If you are going to use your teton for crawling I do not suggest that servo, because it has extremely bad torque.
  4. #44
    Mar 2019
    Can you clairfy?
    Quote Originally Posted by Luke s View Post
    What do you mean by "bad torque"? I have a Summitt truck and the 2065 servo locks/unlocks the differentials. Would the eso8aii servo be good enough for that? I'm so sick of the 2065 PLASTIC garbage!
  5. #45
    Nov 2018
    401
    Quote Originally Posted by GreenSpider25 View Post
    I also recommend the savox servo. They can be very inexpensive and are metal geared which makes them very durable. I got mine for a little over $25. It does take some slight modification to fit, but it worked. Very quick too.
    Ok. I got a servo for $4 that is faster, and has metal gears FOR $4... The savox servo is a great upgrade, but just not as good bang for your buck as the emax eso8aii servo IMO.
  6. #46
    RC Champion Mr Wolf's Avatar
    Malmesbury, UK
    1,667
    Is anyone running the Savox SH-0263MG in their Teton?
    Savox's website says its spline count is 25 (same as the 2065) so I was hoping it might be a straight swap.
  7. #47
    Malmesbury, UK
    1,667
    For the benefit of anyone following this thread, I can confirm that I ended up buying a Savox SH-0263MG for my Teton.
    It fits the stock servo chassis mount perfectly but has a different sized output shaft so I had to use one of the plastic horns that it came with and drill a larger hole in it to fit the stock link arm screw.
    I works great though with a much zippier (0.10s) transit speed. Only negative at all is a little bit of servo chatter in the neutral position that is so typical of Savox servos.
  8. #48
    Jul 2019
    3
    Has anyone tried the Traxxas 2065X?
    Sent from my SM-G960U using Tapatalk
