Page 1 of 2 12 LastLast
Results 1 to 40 of 63
    Feb 2015
    Pinole, ca
    102
    new mini slash owner from norcal
    Ive just purchased my scott douglas edition 1/16 slash from ebay and this is my first step into hobby rc, I've already purchased a second 1200 7.2v battery and parallel connector for longer run time from ebay as well. I'm curious to what quick chargers would be useful since I know it comes with the slow wall charger, and is there anything I should upgrade in the near future? thanks in advance!
    RC Racer ant12hony's Avatar
    Feb 2014
    alberta
    228
    Quote Originally Posted by GearHeadJonny View Post
    I don't own a slash but I am guessing that RPM arms and a T-Bone bumper will help a bit.
    I am better than you!!
    Feb 2015
    Pinole, ca
    102
    ok I've looked into the arms and I've seen some had issues with rubbing and some didn't, maybe a qc issue. I'll keep looking
    1/10 Slash 2wd
    1/10 Slash 4wd
    Sep 2011
    Iowa City, Iowa, USA
    4,357
    I would recommend an onyx 235 charger. Dont charge your nimh batteries together. I second the t bone bumper.
    Jan 2015
    holland michigan
    647
    I have the onlyx 200 and I love it for charging my nimhs. Fast and ez to use.
    RC. an addiction I'm proud of
    Feb 2015
    Pinole, ca
    102
    is the 200 just as good?
    1/10 Slash 2wd
    1/10 Slash 4wd
    Sep 2011
    4,357
    The onyx 200 won't charge lipos later if you choose to go in that direction. Its your choice but I woul recommend buying a good charger the first time.
    Feb 2015
    Pinole, ca
    102
    ahhh ok I'll just wait then
    after looking at the 235 it's out of my reach, would the 200 be a good basic quick charger to get started just for now? I know the wall charger is gonna suck..
    1/10 Slash 2wd
    1/10 Slash 4wd
    May 2002
    Midvale Utah
    1,773
    I recommend getting an "imax b6 ac" charger.... just search ebay.... it's a good charger at a great price.
    Dacaur
    Feb 2015
    Pinole, ca
    102
    sweet just grabbed one for 20
    so I purchased the imax b6 and got the power supply cord, and took a second look to find out its not an ac model but it did some research and it can charge nimh batteries
    what the difference between the regular 1200 7.2v nimh battery and the id version?
    1/10 Slash 2wd
    1/10 Slash 4wd
    May 2002
    Midvale Utah
    1,773
    "ID" batteries have a special plug so a traxxas charger knows what type of battery you plugged in automaticaly. ID lipos also balance through the main connector.
    If you are not using a traxxas ID charger, all you need to know is that for lipos with id, you need a special traxxas Id adapter, since ID lipos dont have separate balance leads. (The balance leads are built into the main I'D connector.
    For nimh, you don't need to worry about it, they will charg with a standard traxxas plug.
    Dacaur
    Feb 2015
    Pinole, ca
    102
    Quote Originally Posted by dacaur View Post
    ok good the second battery I purchased wax an id unit
    so after a lot of research I want to grab a set of these tires and wheels from hpi, has anyone run these or something similar?
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXM975
    http://www3.towerhobbies.com/cgi-bin...RSK5&P=7#mults
    plus I want this merv body
    so I got this today and I'm still at work, can I go home now?!
    my only complaint is the 27mhz version of the radio system
    truck did well on its initial run but I definitely need lipos, and gonna switch to the 2.4 radio system
    just ordered this body for my slash
    1/10 Slash 2wd
    1/10 Slash 4wd
    May 2002
    Midvale Utah
    1,773
    nice. love the bugs
    Dacaur
    Feb 2015
    Pinole, ca
    102
    this was more expensive but has the engine detail
    quick question is there a fan for the titan 380 brushed motor? mine starts getting hot after running dual 1200mah nimh batteries for a bit. still all box stock, I'm asking now so when I switch wheels/tires I can keep an eye on the esc/engine temp from that too
    so my mini slash doesn't like the weight of two nimh batteries and an action cam, rubs the rear fenders pretty bad and since I've got a new body on the way I'm gonna slice the rears and make this my filming specific body
    any suggestions for stiffer springs until I get lipo?
    1/10 Slash 2wd
    1/10 Slash 4wd
    May 2002
    Midvale Utah
    1,773
    With all that extra weight, especially since you are still running nimh, which is even more weight vs changing to lipo, I would say go go with revo or summit springs. The stiffest slash springs are #7143 double black 1.02 rate, the stiffest revo springs are #7148 black 2.22 rate , the stiffest summit springs are #7246 purple 3.2 rate.
    What you get depends on the terrain you drive on. If you are bottoming out a lot over small bumps, you want a stiffer spring. You don't want to try to eliminate all bottoming, or you will go too stiff. At the same time you put the stiffer springs on, I would go with a bit thicker oil too.
    Dacaur
    Feb 2015
    Pinole, ca
    102
    ok cool thanks!
    so I don't wanna drill an antenna hole in my vw body I just got, would my signal drop if I just coiled my antenna cord under the body? I have a 27mhz mini slash, or should I just spend 40 and get the 2.4 conversion?
    1/10 Slash 2wd
    1/10 Slash 4wd
    May 2002
    Midvale Utah
    1,773
    You will lose a lot of range putting the 27mhz antenna under the body. If you don't want an antenna sticking up, 2.4 is the way to go. Even though many 2.4ghz antennas are kinda long, only about the last inch is the actual antenna, so with those it's ok to coil most of it in side the radio box and use a short antenna tube to keep it under the body.
    Dacaur
    Feb 2015
    Pinole, ca
    102
    I've upgraded to 2.4ghz and lipo power!
    they aren't glued yet but I love these
    just need the motor mount and my 550 swap can begin
    1/10 Slash 2wd
    1/10 Slash 4wd
    Feb 2015
    Pinole, ca
    102
    the titan 550 is in
    1/10 Slash 2wd
    1/10 Slash 4wd
    May 2002
    Midvale Utah
    1,773
    Nice. How's she run?
    Dacaur
    Feb 2015
    Pinole, ca
    102
    gonna find out when I'm off work, just finished the rebuild
    everything works but its sooo torquey, are my half shafts ok or shows upgrade lol
    this thing is three wheeling in hard turn s
    Edited for language abuse. If you see a starred out word in your post, you must edit it out to avoid earning warning points.
    1/10 Slash 2wd
    1/10 Slash 4wd
    May 2002
    Midvale Utah
    1,773
    What size pinion are you using, did you just move it from the 380 to the 550? Your drive shafts should be fine. They can handle a lot more than a brushed 550
    Dacaur
    Feb 2015
    Pinole, ca
    102
    yeah just 380 to 550
    1/10 Slash 2wd
    1/10 Slash 4wd
    Feb 2015
    Pinole, ca
    102
    my shocks just started leaking pretty bad..
    1/10 Slash 2wd
    1/10 Slash 4wd
    Jun 2014
    Southern California
    7,478
    The upgraded GTR shocks 7061X are nice:
    https://traxxas.com/products/parts/7061X
    How's your handling?
    Might want to get stiffer springs with that 550 weighing your rig down.
    Probably top heavy as well. Sway Bars?
    Did you ever run that crawler bug body?
    Pics if you got them!
    Feb 2015
    Pinole, ca
    102
    I haven't gotten around to painting it yet, I switched to double black springs on all corners. I've got stock shocks too
    1/10 Slash 2wd
    1/10 Slash 4wd
    Jun 2014
    Southern California
    7,478
    Quick question... why did you get the crawler version instead of the one for the MERV?
    The MERVs should just drop right on. Body dimples for body mounts in the right location.
    The crawler looks like the dimples are on the sides.
    The bodies are similar, but different. Did you get it for the "engine" detail on the back?
    Just wondering.
    I almost got that one, but wanted to keep my wing.
    I'm partial to the bug as well:
    Feb 2015
    Pinole, ca
    102
    yeah engine detail is what got me, Idc if the dimples are in the side I'll make it work lol
    1/10 Slash 2wd
    1/10 Slash 4wd
    Feb 2015
    Pinole, ca
    102
    traction roll sucks tho..
    1/10 Slash 2wd
    1/10 Slash 4wd
    May 2002
    Midvale Utah
    1,773
    yea you gotta watch the steering input.... a radio with expo helps a lot, or just turn down the steering rate.... You could always upgrade to mini revo arms, driveshaft, pushrods, and toe links for the extra width its a slippter slope, this RC thing is.... "after THIS upgrade, I will be happy..." "Oooo, now I need this".... etc, etc.
    Dacaur
    Feb 2015
    Pinole, ca
    102
    Lol do the Revo arms and stuff make the slash better all around?
    1/10 Slash 2wd
    1/10 Slash 4wd
    May 2002
    Midvale Utah
    1,773
    Well, it wont be a slash anymore, but it does make it better for sure. You will get a lot more suspension travel, as well as a wider stance to help prevent rolling... its still possible to traction roll, but less likely.... You will want to go to revo springs too.
    Dacaur
  33. #33
    Feb 2015
    Pinole, ca
    102
    I'll look into it, I've learned to slow for tight totems week this thing
    1/10 Slash 2wd
    1/10 Slash 4wd
  34. #34
    Feb 2015
    Pinole, ca
    102
    so this happened..
    1/10 Slash 2wd
    1/10 Slash 4wd
  35. #35
    May 2002
    Midvale Utah
    1,773
    Yikes man! I would give traxxas a call and see what they can do for you... If you get no joy there, time to go brushless!
    Dacaur
  36. #36
    Feb 2015
    Pinole, ca
    102
    yeah I dunno what happened, I've have the 550 swap for a while now
    1/10 Slash 2wd
    1/10 Slash 4wd
  37. #37
    May 2002
    Midvale Utah
    1,773
    I doubt it was the motor that caused it, they put the 550 in the new ones with the same ESC.... Something failed somewhere and allowed/caused a short....
    Dacaur
  38. #38
    Feb 2015
    Pinole, ca
    102
    as you know my mini slash has been shelved, but it's back with a slight makeover
    1/10 Slash 2wd
    1/10 Slash 4wd
  39. #39
    Jun 2014
    Southern California
    7,478
    Glad you're back up and running... love the "Herbie" look!
  40. #40
    Feb 2015
    Pinole, ca
    102
    thanks and yeah I hella missed bashing around in this thing
    1/10 Slash 2wd
    1/10 Slash 4wd
