Page 1 of 2 12 LastLast
Results 1 to 40 of 52
    RC Champion djmaincheese's Avatar
    Jan 2007
    Gilbert, AZ
    1,381
    Going to give the GRP 1/5 Wheels a try..
    These are some beefy wheels compared to the rear XO stock wheels. Will mount them up over the weekend and see if they are better, worst case they look awesome
    Sep 2013
    269
    What kind of adapter do you run with those?
    Jan 2007
    Gilbert, AZ
    1,381
    r
    Mar 2014
    75
    That should give you a lot more speed too! Looks sexy man.
    Mar 2014
    413
    Looks awesome! And it should a lot more speed. I'm sure you know this but make sure to balance them that's a lot of rotating mass.
    Are those custom hubs, or did you buy them?
    Jan 2007
    Gilbert, AZ
    1,381
    Thanks, I bought them off eBay. They are from RC Hornet, will try to find the link.
    Gilroy, CA
    107
    I have been trying to find those square hubs for the XO with no luck, a link would be great!
    Jan 2007
    Gilbert, AZ
    1,381
    Found it
    http://www.rctech.net/forum/r-c-item...els-tires.html
    The eBay member is rchornet786
    Mar 2014
    413
    Thank you.
    RC Racer ant12hony's Avatar
    Feb 2014
    alberta
    228
    looks sweet dude
    I am better than you!!
    Sep 2014
    awesome... I just finished installing mine on my XO-1 as well, just waiting on my Corvette body... which btw that new 2014 color scheme body looks great with those wheels.
    Gilroy, CA
    107
    Any word on how these tires perform? I am debating making the upgrade... Just emailed Rc Hornet yesterday and they are in process of making more of these hubs for the XO.
    475
    Question I have is whether these tires are good for 100mph. The XO1's stock tires were designed for such use. Having said that, I am definitely interested.
    Jan 2007
    Gilbert, AZ
    1,381
    Good question I have never got mine above 89, simply don's have a big enough area to run it in, hopefully will make a few faster passes somewhere more open as see how they handle compared to stock.
    The tires feel a lot more tacky than the stockers..
    You will need to cut the fenders slightly bigger and trim back some the front and rear plastics to allow for more clearance for the bigger wheels.
    Jun 2011
    10
    That's looks brilliant I've aleady ordered my super soft tires, just waiting for my square hubs from rc hornet.
    Have you noticed a improvement ?
    Jan 2007
    Gilbert, AZ
    1,381
    Thank you, I actually havent had a chance to run them yet. I made a roller for it and found 2 driveshafts were slightly bent so there was some crazy wobble in the front right and left rear tire. New shafts should be here early next week..Just want to make sure everything is 100% before I go tearing up and down the street.
    Mar 2014
    413
    Awesome roller do you have any build specs. Or pictures
    Jan 2007
    Gilbert, AZ
    1,381
    Thanks Neo,
    Here are a some pics of the Roller. .Rollers I got were 15"
    The ends are spring loaded but i think they make threaded ones too..
    The wood going across just supports the sheet metal but you could use a slightly thicker sheet and not need the wood.
    Approximate Measurements, I could have shortened it up a bit length wise but it's..
    L 37 3/4 X W 16 3/4 X D 3 1/2
    Center of the roller in line with the axles
    Little hole for bolt to pass through, cant see the bolt unless you are eye level with the bottom of the chassis
    I used 2 1/2 Washers on each side of the roller so it wouldn't wear the wood too quickly
    r
    I used 1/4 X 3" Machine Bolts that go through the front and rear fender with a washer and butterfly nut on the underside. You can easily adjust how much force you want on the rollers>
    r
    Mar 2015
    3
    Nice car dude .
    Where did you buy those shock springs from.
    Whats the product id!
    Jan 2007
    Gilbert, AZ
    1,381
    Thanks Lanz, got the springs on eBay made by VG Racing
    http://www.ebay.com/itm/390621390584...%3AMEBIDX%3AIT
    Mar 2015
    3
    Thanks dude
    You said you had crazy wobble in two of your wheels make sure that every axle hex insert is torgued up the same.you need a little slop in wheels at high speed you will see they spin true.
    over tighen insert you will see wheels wobble more under low and high speed also may damage pin and warp wheel hub hole for pin.. not to mention side load on bearings..
    also balance your wheels... see how you go!!
    Mar 2014
    413
    Thanks for the build specs
    Jun 2011
    10
    I've received my rc hornet adapters and I used the new Pmt tyres over the weekend.
    Gotta say I feel the traxxas lacked grip, and the lack of choice for different tyres was very disappointing.
    The PMT tyres have allowed me to have some fun with XO 1
    475
    Post some pics ^
    Jun 2014
    Kansas
    3,013
    What's the out come of these wheels. Are they better then stock. How does it do when turning do they rub
    Mar 2014
    75
    Would those wheels act like a propeller at high speeds? I would think solid disks would be better. You dont see that type of wheel at Bonneville Salt Flats!
    475
    Just got my adapters in. Will post pics of them installed. Waiting on the GRP wheel/tire combo.
    Apr 2015
    9
    I luv it. Gets me thinking about my xo1
    Apr 2015
    5
    How's the performance with these?
    Jul 2013
    St.Louis MO.
    62
    Okay I've seen all the photos of the 1/5th wheels on the xo-1 the real question is how is the performance are they better are they worse? Does anyone have any running videos with these larger wheels. We need some info people!!!! If you have made the conversion would love to hear some feedback on how this modifications performs.
    Fastest Radar Verified XO-1!
    Feb 2015
    A place where I have food, shelter, shower, water, bed and internet
    989
    Those GRP tires are sick! They just fit
    Sl4sh, Arrma Talion, Stamp4de, Castle, MIP, RPM
    Portugal
    608
    Hey!
    I would like to know how in the earth do this behave?
    I mean, how are they secured?
    Stock 1/8 17mm anything (buggys,truggys,onroads) are secured by a pin and a set screw facing the pin.
    Not going anywhere!
    But those are just with a set screw? Man...aren't those just flying around inside the dogbone tip?
    Can make a video on the install...rather then just showing pictures of the actual product installed. Or make a pic of what set screw goes inside that set screw hole... i mean is that a long set screw that make 2 things...pin and set screw at the same time? Or what....
    Anyway, thanks for showing that to the world! And this will fit any 1/8 buggy,truggy,on road with 17mm anything hex?
  33. #33
    Jan 2003
    nc
    2,549
    still nothing on performance?
    slash 4x4 168mph
    youtube:philip jolley
  34. #34
    Jul 2013
    St.Louis MO.
    62
    Yeah what's up with some performance info or some video of the car running with these wheels on
  35. #35
    Apr 2015
    5
    Well I bit the bullet and got a set. I will let you guys know how it peforms when I have time to run it.
  36. #36
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by melski415 View Post
    Yes please do. Which compound tires did you end up getting
  37. #37
    Jan 2003
    Illinois
    142
    Looking sharp. Liking them a lot and hope they work well.
    Curious whether either of you are running with a gyro? Seemingly a necessary piece of equipment for a power plant suck like the XO-1. I'm about to pull the trigger on an XO-1, thinking I'll need to pick up a set of new wheels/tires too ..
    Raz
  38. #38
    Jan 2003
    Illinois
    142
    Assuming you guys went with the new P3 compound?
    http://www.grpgandini.it/index.php?o...emid=6&lang=en
    Where are you purchasing from? Right, hope they produce at the higher speeds..
    Also, can't seem to find a link for RC Hornet? Had hoped to send them an email regarding adapter availability.
    Raz
  39. #39
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by Razmo View Post
    Raz
    I searched 1/5th grp wheels and tires on eBay.
    Brucknerhobbies.com is a main place I see that sells the grp wheels and tires
  40. #40
    Dec 2014
    right behind you...
    85
    Didn't you eventually list this on craigslist? I saw it a couple times, did it ever sell ?
    E-Revo
    If it ain't broken, upgrade it!
