Results 1 to 11 of 11
    Edmonton, AB (and looking for an RC buddy. PM me if you're from NE Edmonton!)
    406
    Green Light Flickers on ESC
    When I go to power up my ESC, the light flickers. It's not flashing like it's in programming mode, it looks more like a flickering neon sign. It also does not respond to transmitter input and the receiver light flickers red. It worked fine the last time I used it (few months ago).
    It seems like a bad connection inside the ESC case, but I'm not positive. Has this happened to anyone else? Thanks!
    Sig edited for awesomeness. NC
    Jun 2014
    Southern California
    7,577
    Check your Tx batteries?
    406
    They're fully charged. The TX worked with my Rustler 10 minutes before.
    Feb 2015
    North East Georgia, usa
    36
    I would think that the throttle trim is off and the esc will not arm. Try to recalibrate the esc. Just a guess..
    p4de-CC2200
    sl4sh-CC3800
    many others R.I.Pieces
    406
    In the manual it says the ESC will flash green steady if throttle trim is off. The flickering is nowhere near the same pattern as the flashing.
    May 2002
    Midvale Utah
    1,773
    Try unplugging your servo... if it's bad it could be shorting and overloading the bec. If throttle works with servo unplugged, servo is bad....
    Dacaur
    Feb 2015
    36
    +1 also check to make sure no wires are pinched... I almost lost a BEC because of a fan wire that got pinched in a receiver housing.
    p4de-CC2200
    sl4sh-CC3800
    406
    Quote Originally Posted by dacaur View Post
    This must be it. I unplugged the servo and the ESC & rx lights are green. If I plug in the servo while the system is on, they go all flickery. Then unplug and they're back to normal.
    Now the real question. How does a servo fry itself from sitting on the shelf?
    May 2002
    Midvale Utah
    1,773
    Dunno, it just does... When it happened to mine, it worked one day, it was working when I put it away, then a week later I went to drive it, and nothing....
    Dacaur
    Feb 2015
    36
    I would think it would be caused from an initial surge of power when connecting the battery to the esc... Maybe it goes over 6v for a split second. That would be all it takes. A glitch buster may help prevent future problems.
    p4de-CC2200
    sl4sh-CC3800
    May 2002
    Midvale Utah
    1,773
    That's very doubtful unless there is something wrong with your ESC...
    More likely the thermal expansion/contraction from the servo cooling down after use just caused a failing solder joint to fully fail....
    Dacaur
