    11
    velineon motor problem
    Ok so I was confused on why my slash would not move so I opened the dust cover to see that when I have it gas the shaft would not turn if it was on the ground. It turn if I lifted the back end up. its the velineon 3500
    Jul 2014
    NAWLINS
    3,952
    Are you talking about the motor shaft is not spinning?
    If the spur gear is turning when you throttle up you more then likely sheared the pin under the top gear. Easy fix with a 1/16 drill bit or new shaft.
    T/SportMax/Slayer Pro/Bandit
    Stampede/Rustler
    Jul 2014
    NAWLINS
    3,952
    Just noticed your other post with the same question. If you look at the pic posted you will see the pin going through the shaft. slide the gear back and check the pin. If it's ok you may have internal motor problems like the magnets came off in which case if you have the will to remove the motor can to inspect you may be able to reattach the magnets which I have read others doing with and without success.
    Stampede/Rustler
    11
    Yes the motor shaft, sorry about that. the spur or pinion doesn't spin. I held the motor shaft to make sure
    Mar 2014
    Ghent - Belgium
    355
    motor rotor probably came off the shaft.
