Results 41 to 80 of 81
  1. #41
    RC Qualifier dr frankenstyle's Avatar
    Dec 2013
    Rural MO ... in a haunted garage
    313
    Thanks, and yessir, you have a good eye. I looked for something that would match the trailer wheels (truck's front wheels too) and fit the old Proline "Stryker II"s that I wanted to use. They're 2.2's (from the '80s), so I had to trim out the beads and stretttch them over the 2.8 Jato wheels, but they gave me the result I wanted, all matched up.
    Oh, and I just realized that you can't really see what truck it is.... so ...
    it's Vaterra's '68 Ford F-100, short-bed.
    chop it up ... stitch it up ...It's ALIVE !!!
  2. #42
    RC Turnbuckle Jr. nitrostarter's Avatar
    Jul 2002
    Gramercy, LA
    3,892
    Nice wheel and tire combo. I really like this little old revival.
    Emaxx- truggy/CD conversion...
  3. #43
    Dec 2013
    313
    Thanks, I wanted something that you don't see everywhere.
    It's kind of a nostalgia build for me. I had a 1:1 of this truck, rebuilt the motor, front and rear-ends, refurb'd the interior swapped to auto' trans' added power-steering and AC. Then I got married, traded it off for an SUV, yatta yatta.
    Anyway it's added to the fun, building another '68 shorty.
    And I gotta admit, "re-animating" the old RC-12 has definitely added an extra level of fun too.
  4. #44
    Dec 2013
    313
    I got the Leopard system installed, set up and tested today. It's purrrrfect !!
    Now with the lower gears it has a nice manageable slow speed for towing, and with an easy gear switch it will wheelie on every launch (flip on it's back if you're too heavy on the throttle )
    Also did a first-shot mock-up for an aluminum chassis ....
    ...that should give me plenty of room for electrics and even room for a pair of 3S if I want ....
    I'll trim it down some before I cut metal, but that's the gist of it.
    I finally got started on the body too. First stage masking, ready for some "Mazda" purple.
    This will be fun! I plan to set it up with some removable wheelie-bars to swap for the hitch, so with a simple gear change it can go from the drag-strip to draggin' the boat to the lake.
  5. #45
    Feb 2002
    9,352
    so does this have an aluminum chassis yet? or still the balsa wood?
  6. #46
    Dec 2013
    313
    No aluminum yet. I worked on the pattern today, but haven't cut metal. And it's actually scale plywood, it's 4-ply for just a little flex. I still have the original, fiberglass chassis from the "e" but it's cracked from being hit twice by "big" cars.
    I'll start cutting and shaping soon, and post pic's.
  7. #47
    Jul 2002
    Gramercy, LA
    3,892
    That is a super cool rig. I'm sure it has plenty power now.
  8. #48
    Dec 2013
    313
    Thanks, and yep, she'll flip without trying. I can play with the gearing more, now that it's better-controlled power.
    It's supposed to be dry and warm for a couple of days, so maybe I can get some aluminum cut and some paint slung into the body.
  9. #49
    RC Champion traxxasfan21's Avatar
    Nov 2015
    in sunny CA
    1,113
    Quote Originally Posted by dr frankenstyle View Post
    Nice pun you got there.
    This is a really cool little summit you got here. Wish I had the budget to do something like this.
    Too much power is just enough
  10. #50
    Jan 2015
    holland michigan
    650
    Sweet build. I love the custom chassis! Will continue to follow this awesome project
    RC. an addiction I'm proud of
  11. #51
    Dec 2013
    313
    Thanks, traxxasfan21, I have kind of punny view on things at times. I'm guessing you've checked out my actual mini-Summit thread below, it's pretty wild too. THIS truck started with NO budget .... then it turned into so much dang fun.
    Thank you, slashcrazy, it's just the lunatic engineering of a mad-scientist.
    But here's an update...
    it was nice again today, so I got silver shot inside the "Phantom Purple", ready for the white.
    And I got the chassis plate to the jig-saw and got her all cut out and ready for "brake-time".
    and the fun keeps rolling...
  12. #52
    Dec 2013
    313
    It was a busy day. After "brake-time" this morning I had this ready ...
    ...that fit the old plywood and body like this....
    and this.
    So it was time to get the plywood out of the way and .... may I present my RC-12e - volved.
    I widened the front track by 10mm and added 5mm to the wheelbase, so it fits the body a bit better.
    I guess I should have given the purple a couple more days to cure, because my white seeped up under the edge and looks like little white grass growin' out of the top edge in a couple of places, daaang.
  13. #53
    Jul 2002
    Gramercy, LA
    3,892
    That's such a cool rig. Nice job on the tub.
  14. #54
    Dec 2013
    313
    Thanks, it should let me shift a little weight back and forth to go from draggin' the trailer to draggin' the "wheelie's". Enough room for a pair of 3S too, for some real wheelies.
  15. #55
    Dec 2013
    313
    I still have a lot to finish up, but I think she's gonna look pretty good in front of the boat.
    More "comfortable" out front than the Punkin was anyway.
  16. #56
    Dec 2013
    313
    It didn't quite get warm enough to paint today, so I soldered up some wheelie bars.
    Here is a close mock-up, the wheels will sit a bit higher.
    They'll be adjustable, so I can raise and lower them a little.
  17. #57
    Jul 2002
    Gramercy, LA
    3,892
    Now that's rad! Slick job there! The wheelie bars look killer. And the paint job matches that boat nicely.
  18. #58
    Dec 2013
    313
    Thanks, nitro', I still have to shoot a couple coats of clear over the paint repair , and then I'll add the blue pinstripe on the truck to finish off the match-up.
    Got primer shot onto the wheelie's this eve'. Need to find some hose to use for "tires".
  19. #59
    Dec 2013
    313
    Got the 'bars painted, cleared the body-fix too. Then cut some wheelie-"tires" from silicone hose. I think they look like urethane wheels.
  20. #60
    Jul 2002
    Gramercy, LA
    3,892
    Bravo! Let's see a video of it running.
  21. #61
    Dec 2013
    313
    Patient ... you must be, young jedi. Lots to finish up ... I have, yes? A video ... there WILL be , hmmm? In the future .... not too distant , hmm ... yes.
    Oh, and I got a pair of 3S batt'ries comin', so I'll have some lipo "NOS" to try in this and the boat.
  22. #62
    Dec 2013
    313
    If I can get the right link, here's a short vid'.
    http://vid1315.photobucket.com/album...psthazyb28.mp4
    Still have lots to finish, but the fun has started.
  23. #63
    Dec 2013
    313
    Got the 3S's yesterday. Here's another short vid' with a few launches. I have 4oz. of weight in the tail-end, to get good traction.
    http://vid1315.photobucket.com/album...psdf0e9djg.mp4
    She'll plant the wheelie-bars from a rolling punch, going slightly downhill.
  24. #64
    Dec 2013
    313
    Well, here's the "Coffin Jockey" in her "Shoe-shine" guise (see above for the Underdog persona )I got the pinstripes on so now the ensemble is more complete.
    Still have lots of details to finish, but she's getting there. Prettier than Punkinstein out front, at least.
  25. #65
    Dec 2013
    313
    Got a back bumper made, from 2 pieces of alum' rod (3/8 and 1/4 in.) I milled a flat side on both rods and cut out for a license plate. Then I decided to cut a slot for the trailer-plug to go thru the bumper, to keep it out of the way for the 'bars and 'chute.
  26. #66
    Apr 2016
    4
    Very nice build!
  27. #67
    Dec 2013
    313
    Quote Originally Posted by kingnba6 View Post
    Very nice build!
    Thank you,
    I got the bumper mounted today, with the light plug installed. Nice and snug, but plenty of room for the hitch ....
    ... or the wheelie's.
    And room for a 'chute set-up too.
  28. #68
    Dec 2013
    313
    Just wanted to share a current pic'. I got the lighting in, cut the front body-posts and installed the magnetic hold-downs, "disc-brakes" in front ....
    .... and the beat goes on.
  29. #69
    Jan 2016
    305
    thats some attention to detail. Love the build.
    Sent from my SM-G900V using Tapatalk
    Maybe add a cooler or a floatie on the bed of the truck to hide the body mounts?
  30. #70
    Dec 2013
    313
    My '53 Ford VXL and friends ...
    [QUOTE=Tacobox;6223135] thats some attention to detail. Love the build.
    [QUOTE=Tacobox;6223137]Maybe add a cooler or a floatie on the bed of the truck to hide the body mounts?
    Thanks I've kinda fallen in love with her too.
    And .... got it covered .... ARRarrarrarr
    I stitched this up a couple days ago. I may add some scale "snaps", but it's good 'nuf for now.
    Now she has a "skirt" to match the boats "jacket".
    I started working on a set of "lakes" pipes for her today.
    Still need to polish 'em up and paint inside the trumpets, then make some plugs for 'em ..... and other stuff.
  31. #71
    Jan 2016
    305
    That's sweet. I really like the cover. Should use a crown royal pouch and put the gold crown in the middle
  32. #72
    Dec 2013
    313
    [QUOTE=Tacobox;6223251]That's sweet. I really like the cover. Should use a crown royal pouch and put the gold crown in the middle.
    Thank you, I ran a piece of steel wire in all 4 sides of the "tonya", and glued more magnets under the tops of the bedsides to hold it down.
    And me and the king quit hangin out years ago.
  33. #73
    Dec 2013
    313
    Just wanted to pop a quick update on the Coffin Jockey (boat puller ).
    I got the 'chute pack made-up and on her. Got the sport side mirrors painted and on too.
    And here's a short "Burnout" video ..... if you frame thru, you'll see her pull the front wheels when I let go. .... and she left double stripes on the porch.
    http://vid1315.photobucket.com/album...psuxis0g2c.mp4
    Oh, and here are the pipes so far.
    " .... and the beat goes on. ...."
  34. #74
    RC Qualifier Swampthing's Avatar
    Houston, TX
    472
    I'm in awe dude! Amazing work!
    Rustler | MERV | Summit | Slash Ultimate | Slash
  35. #75
    Dec 2013
    313
    Thanks The Coffin Jockey has gotten a few more upgrades since my last post. I added some exterior door handles that I made and polished all of the alum' parts.
    I also built a full interior ....
    I used Axial bucket seats, and scratch-built a dash with back-lit, aluminum gauge panel, polished alum' roll-bar, carpet, etc ...
    I still have some more details to finish, right now the steering wheel is just taped in .....
    .... and I just reworked the steering servo set-up so I'm itching to drive it some more.
    And I've been playin' with the FPV system in my crawler.
  36. #76
    Dec 2013
    313
    I wanted to share this. I recently grabbed a new 3ch TQi set with the Bluetooth module, then got a set of telemetry sensors for a T-Maxx, and put it all in my Pro-Street truck. I just soldered a tap-wire into the ESC's pos' wire for the voltmeter, then wrapped the temp sensor around the motor, so those were easy.
    Then I cut the sensor holder off of the mount and epoxied it into the GRU for my truck ....
    .... and drilled an aluminum gear (opposite from the grub screw) and CA'd 3 small neodymium magnets into it for the trigger.
    After shimming the gear close to the sensor, bingo ....
    ..... we have a working "dash" display.
    Then I cut a cardboard bracket/support for my Ipod touch....
    and with the belt clip (on my $6 case) it clips to the top of the Tx,
    the long tab lets me hold it to the back and makes for easy view.
    I also added more details .... carved a balsa wood scoop .... hood pins .....more interior detail ..... Catwoman as a driver .... and made a new shorter set of wheelie-bars.
    I LOVE the TSM, it lets you tweak it to the available traction "on the fly" and keeps it straight as a rail in the quarter-mile. And now the "dash" lets me monitor everything from the Tx. TOTALLY AWESOME TRAXXAS!!!!!
    The speedo' isn't quite calibrated to my gears and tires (it shows a top speed of 66-mph, I don't quite think so .....) but it sure makes my buddies (and me) smile a lot.
    Thanks for lookin'
  37. #77
    Apr 2016
    Midwest
    1,006
    That looks awesome, literally awesome. Keep up the good work.
    "Gone racing"
  38. #78
    Dec 2013
    313
    Thanks, It just keeps getting more fun.
    I got my DTS-1 set up (in my living room) and all connected to my Ipod AND the truck. Now I just have to take it to town and find a clean, empty parking lot to give it a proper field test. I'm anxious to get a speed trap reading, and see how my reaction times are.
    I'll post up a time-slip when I get some.
    Thanks for checkin' it out.
  39. #79
    Oct 2016
    utica ny
    115
    awesome collection, are they brushless
    Everything dies..everything..no,no,no,no
  40. #80
    Dec 2013
    313
    Quote Originally Posted by TypeONegtive View Post
    Thank You, and yes, they are now. I originally built the truck and boat with brushed set-ups, but then I upgraded the boat with a ProBoat 1500-kv and put a Leopard 3300-kv setup in the truck. Then recently I switched to a 4-pole motor in the truck for better low-end punch and stronger brakes. The yellow truck is VXL with a Dynamite Tazer ESC.
    I took the DTS-1 to town today and made a few passes. Here's a time-slip from the second run ....
    .... and the first run, with a little better reaction time, speed and ET.
    I deep-staged the second run, so I was a little nervous on the light.
    Thanks for lookin'
