Results 1 to 10 of 10
    Sep 2011
    North Jersey
    90
    1/16 revo won't move
    If the slipper clutch pads are bad will it cause the truck not to move?
    Drive it like you stole it
    Sep 2011
    Iowa City, Iowa, USA
    4,361
    It depends how bad they are. Is the motor trying to move? Maybe just try tightening the slipper clutch.
    Sep 2011
    North Jersey
    90
    The pad looks pretty worn down I've had the truck since the first day it came out. Tightening the slipper clutch doesn't make a difference and diffs are fairly new.
    Sep 2011
    4,361
    Does the motor spin?
    Sep 2011
    North Jersey
    90
    Yes it does
    RC Qualifier dr frankenstyle's Avatar
    Dec 2013
    Rural MO ... in a haunted garage
    313
    With the gear cover removed, you can hold the transmission shaft (with a small allen wrench thru the shaft sticking out the front) and turn the spur gear by hand to feel how loose the slipper is.
    On the right track, I think you are... young jedi
    chop it up ... stitch it up ...It's ALIVE !!!
    Jun 2013
    LaConner, WA
    368
    You will hear w whining noise from the slipper when worn out when you hit the gas..
    Jun 2014
    Southern California
    7,594
    Many possibilities:
    Motor unglued
    Bad slipper pads
    Slipper needs tightening
    Bad pinion/spur mesh
    Bad pinion or spur
    Broken/stripped tranny gears
    Broken shaft drives
    Gotta start taking things apart to properly diagnose!
    Good luck and keep us posted!
    Sep 2011
    North Jersey
    90
    I've had the truck since the first day it came out and the new slipper pad vs the old looks nothing like it. I just have to put it back together and test it.
    Colorado
    450
    I had this symptom - in my case i had melted the slipper into the spur gear - needed new spur and clutch disc - got to love 3S Lipo
