Results 1 to 15 of 15
    Apr 2015
    clarkesville ga
    19
    problem with latrax rally diffs
    ive been having this problem where my latrax rally will sound like the gears are shatteed but i take the whole transmission apart and it all looks fine whats the problem with it?
    Apr 2015
    clarkesville ga
    19
    Apr 2015
    124
    Buy the differential set for the teton and put them in, the ring and pinion are metal
    Apr 2015
    124
    Have you looked at the motor pinion and spur?
    Apr 2015
    clarkesville ga
    19
    Yes I have looked they are fine
    Apr 2015
    124
    I watched the vid, it must be the plastic diff gears are stripped. new teton diffs are a must. one of the most meaningful things you can do to a rally
    Feb 2015
    10
    Is this the part to buy then? http://www.rcplanet.com/Traxxas_LaTr..._p/tra7683.htm
    Do you put this in front and rear?
    I have the same issue with mine. I replaced the Traxxas Pinion Gear Diff LaTrax (2) TRA7578 on the rear and it worked for like two laps and now it will spin fine in my hands but once I put it on the ground it it barely moves. The only thing that looks maybe not 100% is the big gear from this http://www.rcplanet.com/Traxxas_Diff..._p/tra7579.htm
    Apr 2015
    124
    That is the rally stock diff, you want the diffs from the teton/sst. Amazon listed the teton diffs at like 38 bucks but the sst ones are cheaper even though they're the same.
    http://www.amazon.com/gp/aw/d/B00QA2...rds=latrax+sst
    That's the one you want, it comes with two one up front one in the rear
    Apr 2015
    124
    And I'd recommend locking the rear diff with superglue or shoe goo, helps let out the back end for drifting and keeps you going straight when drag racing
    Aug 2014
    172
    Quote Originally Posted by cburbs View Post
    Yes,buy two sets of these. The TRA7579 rebuild kit will work with all three LaTrax models. Just use the metal spur and pinion gear (TRA7683) instead of the plastic ones. Use some ASC21141 shims to tighten the gear mesh.
    You don't need to spend $30 to keep it on the road. Once you get the metal gears(TRA7683)you will just need the rebuild kit to fix your diffs.
    Good luck !
    Dec 2013
    95
    Quote Originally Posted by Myrallyisfaster View Post
    On that note, Traxxas does have an Aluminum Spool. (#7581)
    Jul 2015
    36
    Piggy backing off an older thread, our SST stripped all the plastic cogs in the metal gear (Part #7683), and on the plastic sleeves drive shaft sleeves (part #7579)
    We have the metal spur and pinion gear, but all the surrounding gears have gone. Is there a metal replacement we can pick up for the remaining pieces?
    Nov 2016
    3
    Same Problem - Replaced Diffs
    I've got the same problem with my LaTraxx as the OP does in his video. I replaced the front and rear diffs with the metal diff set (7579x). The problem was reduced for a few minutes but then went right back to the original issue. I'm not visually seeing any stripped gears and I've torn down the whole thing. I called Traxxas and the guy kept insisting it was the motor because "sometimes the brushes go bad," and "it's usually the motors with these." I couldn't hold on to the drive shaft when giving throttle, the motor was so strong but I replaced it anyway and still no change. Does anyone have any suggestions on what else to try? The closest hobby store is 50 miles away. I'd rather not go that route.
    Nov 2016
    3
    Just wanted to follow up on this in case anyone else runs across this thread. I actually found it with a Google search. The OP mentioned in the comments on his Youtube video (linked above) that the solution was to replace the plastic / nylon bushings with the metal bearing kit. Since replacing the diffs didn't fix it for me I tried that as well and sure enough, it worked. Not sure if the plastic bushings were binding up and maybe blocking axle spin or something else but getting those cheap plastic ones out made a difference. This was a particularly odd problem because none of the gears were visibly stripped.
    There are several bushings on the drive shaft, two in each wheel and of course two on each diff. I went ahead and replaced them all since they all came in the kit.
    Nov 2018
    401
    Quote Originally Posted by katwitch View Post
    Also metal gears sound like shredded plastic gears sometimes, even if they are completely fine.
