Results 1 to 13 of 13
    Apr 2015
    7
    Car won't start up
    Hi, My nitro slash 2wd wont start up. At first i thought it was the blue wire cause it was stuffed up and i had to fiddle around with it to get the glow plug light to turn on the ez start wand. So i asked on the community if i could get a glow plug igniter instead of getting a blue wire and said yes. I bought a glow plug igniter charged it for 12+ hours and went to try and turned it on. NOTHING!!! I need help i took some videos and photos to give you an idea.
    Thanks, Jonathan.
    Blue wire:
    http://i483.photobucket.com/albums/r...psln8sg07c.jpg
    Glow plug video:
    http://vid483.photobucket.com/albums...psq6tmh7g4.mp4
    Starting car video:
    http://vid483.photobucket.com/albums...psjuk77mj0.mp4
    Gurley, Alabama
    802
    You need a new glow plug, they should glow bright red.
    13,497
    Fuel + compression + glow + air = a running engine. Take one away and you have nothing.
    Apr 2015
    7
    So what do you think i should do?
    Quote Originally Posted by Mark Ball View Post
    I tried two glow plugs in that video
    13,497
    If you have a multi-meter probe the two contacts to make sure you are getting ~1.5v coming out of it. One glow plug I could see, but two and you may want to look at the ignitor. The likelihood that a glow plug is bad out of the package is there but it is very small. I would be mad if I bought a $5-7 plug only to have it bad out of the package.
    Apr 2015
    7
    alright ill get a new glow plug and see what happens
    May 2014
    ohio
    1,300
    i have had brand new glow plugs come with out a COIL, but let us know what you find, i would suggest getting a pull start over the NOT so Ez start. no wiring issues that way and no mad 15+ minute trips back home after a dead battery\ short in the starter motor.
    you can turn the engine faster by hand with a pullstarter than with an elec starter, if you want the best starter get a roto start or "drill start" turns over the fastest, just have to carry around a drill
    2.5r Pede, 2-speed O.S.21tm rusty , 3.3T-maxx
    May 2015
    Hi from Norway.
    My son New traxxas will start, but dies when i remove electric starter. Do i need to replace the glowplug?
    Never mind spelling, i'm from norway ��
    May 2014
    ohio
    1,300
    Quote Originally Posted by Norwegianboy02 View Post
    Hi from Norway.
    hi and welcome to the forums, with a new vehicle they always set the engine to be RICH for the break in process, however that can give some issues when trying to start up depending on location but i do not recomend changing the tune before actualy driving the truck, hold the trigger down slightly to keep the truck running or increase the idle cap on the engine to keep it running just at a slightly higher idle.
    generaly you WILL have to hold the throttle somewhat open when starting a nitro rc, it is normal to keep it running, once it has started and begin to warn up to operating temp you should be okay with it at idle for a few seconds (10-20) with proper tune
    May 2015
    Hi thanks for reply.
    The car starts, and we have byen driven quite a lot actually.
    Trouble now is: when i start The car with The el starter it runs, when el starter is connekted, but as soon as i remove el starter it stops emediatly
    RC Qualifier Devon_4's Avatar
    May 2014
    BC, Canada
    304
    Its usually a good idea to leave the starter/glow igniter in the car for a while after starting. It just lets the plug warm up.
    Two stroke smoke
    Jul 2014
    6
    glow plugs go bad often. always try a new one first.
    Nov 2015
    NW Ohio
    15
    If you are done breaking in engine and motor dies after you remove glow starter, can sometimes mean you are running rich on your low speed needle. I had that issue previously, was rich on low speed needle and lean on high speed needle and it seemed to run decent but wouldn't idle well/would die after removing starter (unless I kept throttle 1/3 open) and would die after a decent wide open blast (as the puddled fuel from being rich down low burn off with being lean up high). This situation had me fouling glow plugs like crazy. Before I replaced pipe and carb - when it was still stock - I'd only change glow plug every gallon of fuel and more of a preventative measure, not because it needed it.
