Results 1 to 2 of 2
    Apr 2015
    Edmonton Alberta canada
    One day it's doing wheelies,the next min...
    I was running beautiful the other night,huge wheelies then it died. I could fire it right back up and would idle fine but would die when I excellerTed it would die. Not only that but I had fuel leaking everywhere. So upon inspection I found out loctite on my head screws hardened and kept the head from sealing . So corrected the problem,now it will fire up nicely and idle, drive around for about a min then completely dies with no warning. Doesn't matter what part of the throttle spektrum I'm in it dies and just rolls to a stop. Anybody have any pointers or advice? Thanks for your time.
    May 2014
    ohio
    1,300
    This honestly makes little to no sense at all. Loctite is a thread locker to prevent screws from comming loose. It also hardens immediately. If your spraying fuel from the head. Remove the head inspect the gasket and the piston.
    2.5r Pede, 2-speed O.S.21tm rusty , 3.3T-maxx
